Drag Racing Tech
meziere race pump setups
Old 02-03-2013, 01:01 PM
  #41
studderin's Avatar
on the stock rad?
Old 02-03-2013, 03:25 PM
  #42
BennyB's Avatar
Originally Posted by studderin
on the stock rad?
Yeah stock radiator
Old 02-04-2013, 05:11 AM
  #43
BennyB's Avatar
I want to be sure before I go through and make the purchase
Old 02-11-2013, 12:24 PM
  #44
BennyB's Avatar
Anybody?
Old 08-14-2013, 04:13 PM
  #45
studderin's Avatar
update
stock rad lower fitting in 1 1/4
stock Wp lower fitting is 1 1/2
if you get the 1 3/4 lower fitting on your pump its very hard to find a 1 piece lower hose to match to the stock rad.
So get a 1 1/2 or 1 1/4 fitting with the meziere race pump is alot easier to find a hose to match up with.
If you get the 1 1/2 fitting install it in the passenger side. If you dont have a spanner wrench/Big *** snap ring pliers to tighten the fitting, and dont want to clamp on it. you can use two small punches/pins/nails ect. in a vice and turn the pump on them to tighten the fitting. And use to plug the driver port. Gates hose # 21191 fits lots of GM 80s trucks and works good for a lower hose, the bend is right, just trim the end(s) down *note- the tag puts hole is the hose so try to cut that part off too
Its 1 1/2 one end 1 1/4 the other,
Old 09-05-2022, 10:53 AM
  #46
TA1364's Avatar
update
Thread is old as dirt but I’m back in the f-body game and this is still helpful. Thanks!
Quick Reply: meziere race pump setups
