meziere race pump setups
Not sure about the HD one or notWP119S (35gal), WP119SHD (40gal, and a pound heavier)
For street driving. With no Tstat I think you can flow to much coolant thu the rad so it dosn't have time for it to remove heat.So It might be better to have the slower/less coolant flow. Any run both, or notice a different between to cars on this? 35GPM vrs 45 or 55gpm?
Street driving, with the stock radiator I want to use. Its light and easy to work with, for the lower radiator hose. I found someone using a c4 vette 1988-89 hose, and the gates PN 21191. That looks like a longer hose you can cut down to work. But what size fitting to use with the WP, it dosn;t come with the lower outlet fitting, so you can get 1 1/4 or 1 1/2?
https://ls1tech.com/forums/drag-raci...nlet-hose.html
Looking for a setup for the stock radiator, for a simple one piece hose that fits good. No clamping steel tubing on 2 pieces of hose, or putting 1 1/4 hose over a 1 1/2 fitting getto junk.
Most of the pics of setups dosn't work searching, or its race cars with smaller alum rad.
thanks guys.
like you said no thermostat, could be a issue on longer street drives. as far as hoses, on my race car I used the 35gpm, with -16an hose, so I would be of no help in that area.
Good luck on your findings.
I can loose some weight with the new rules for AM WCF. My heater is about 10, so looking to get the race WP so I can ditch the stock one and tencenior and run the BMR alt bracket, the race WP are a light lighter and cheaper then the street one.
Get the Meziere 119HD.
Meziere 1.50 Inlet Nipple. WP1150
The lower hose from a '89 Corvette. Stock top hose w/o ps cooler.
I got both from O' Reilly. Gates. Part #22352 and #21727 forgot which is top and bottom.
But that's them.
Also, I have a BMR Alt. Relocation Bracket. Belt is # K060345 Gates.
The Corvette lower hose has a 1.50 inlet on the pump side. And a 1.75 inlet on the rad. side.
MikeF@S-K Speed has the lowest price on the pumps, that I found.
I posted a pic of the stock. I htink it was 12-13 with the tennior. And thats on the front of the car, a Big deal for loosing weight. this with me going to one fan is gona asve like 12-15pounds just in the cooling system
.Gates. Part #22352 and #21727 forgot which is top and bottom.
The mezeire street WP is actually a bit heavier than the stock WP.
Why is the race pump not streetable? Mine seems to work just fine
Street driving..
https://ls1tech.com/forums/drag-raci...ld-thread.html
So no one has heat with the race pump??
so sick of this race car/street car BS asking about a part, and general info and facts. Thanks but your opinion has nothing to do with the thread, and I don't care if you think you have a street car or not.
somthing like this
http://www.speedwaymotors.com/Gates-...nch,34054.html
You guys can post some pics too, the older threads don't have pics anymore.
Ya, I was thinking about that too. If you could just get the ribbed flex hose ti connect the lower rad to the WP and not worry about the 2 pre made bends. The stock rad is 1 3/4.... right? so you just get the metzire 1 3/4 fitting, and the universal flex hose 1 3/4. Do you know what the length is.
somthing like this
I was hopeing someone had some pics or info about hooking up the heater with a race pump and if it would cool pulling up hill with a ac condensor in front of it.....you know, the stuff a street car has to do.
Not really, I wouldnt drive my car in the Winter, I consider mine a street car.. Just cuz you drive it all year round doesn't mean ****. What about the cars that didn't cme with AC or power windows? Or if the car is just on a diet? I think your just jealous!!!
Sorry to hijack your thread! I think the street car / race car talk is what u consider it as.. I'm in for info, wish I had some usefull info
somthing like this
