Am I being ripped off?
I received my bill today and by the way they kept the car for about 60 days. I called them periodically checking on my car. They never contacted me unless I contacted them first. The damage was $5,600. I got charged $85/hr. Hours spent on the rear: 16. Hours spent on everything else: 27. The parts I bought from this shop totaled roughly $1,600. Does this sound right or am I being taken advantage of?
Removing the brakes/backing plates - 1 hr
Assembling the moser (putting the backing plates & pressing bearings, installing the center section, bolting the torque arm bracket on (moser's are not shipped assembled))- 2 to 3 hrs.
Installing the rear axle - 1 hr
Attaching the brake line to the new axle (Fabbing bracket as one dosen't come with the moser) - .5hr
So I could see 5.5-6.5 hours easy. 16 is a bit much...
Even with time wasted Looking for the correct socket, missing bolts, bleeding brakes yelling at the wife to push the pedal etc..etc...I can swap a rear end in about 5hrs or so...Someone who has a lift, the correct tool, has done the job a few times...should be done in a jiffy. You got taken not only for the amount of time, but $85 hour!!! Nobody deserves to make that kind of cash doing non-technical task. With the right tools, anyone can do it.
Good luck but see if they will work with you. You were a fool to just drop the car off to them, but lets hope they work with you and don't completely screw you because of you ignorance and foolish decision.
Yes, lesson learned
