Drag Racing Tech
pulling front tires ?
Old Nov 13, 2012 | 11:27 AM
speedtigger's Avatar
Old School Heavy
Originally Posted by joelster
If they set the front shocks on full stiff and raise the front end, they lose .05 in the 60ft and .15 to the quarter even though the car still dead hooks.
Probably a stick shift car then? That can happen if you lose wheel speed.
Old Nov 13, 2012 | 03:42 PM
Justinktm's Avatar
i just want it for the picture sake and bragging rights then after that i dont care
Old Nov 13, 2012 | 05:43 PM
N2RACINGLS1's's Avatar
At least!
N2
Old Nov 14, 2012 | 03:30 PM
exodus_gs1's Avatar
Originally Posted by NC98Z
Your running road racing tires at a dragstrip. If your set on NITTOs then get you a set of the 555r tires. Better yet get a set of Micky Thompson Drag Radials. Set the rears at 18#s and then tell us what happens.
he has the nt05r's which are the softer sidewall and compound for a more drag oriented version. Now I have nt05's which have the stiffer sidewall and compound for roadracing.
But Justin I'd listen to lemons12 dudes got some know how. But it would. Be a badass picture. One day I'll be able keep up
Old Nov 14, 2012 | 04:37 PM
Justinktm's Avatar
im just wanting one for a picture sake i mean how badass would that be to do a wheelie and stare at sky for a little bit lol im only 19 so it would be great since none of the people i hang around are close to doing it
Old Nov 14, 2012 | 05:59 PM
Here you go use this one until you get your car up in the air Good luck!
N2
Attached Thumbnails pulling front tires ?-n2racingls1-s-bumper-drag-2011-2011_02_13_16_14_21-3-.jpg
Old Nov 14, 2012 | 06:15 PM
exodus_gs1's Avatar
O yea I get that. I would like to also... I really wanna do it on the street. Just sitting at a stop light and boom all the way across. Thats the photo/video I want
Old Nov 14, 2012 | 07:19 PM
lemons12's Avatar
You aren't anywhere close to anything like that... You can pull the tires with what you have.
Adjustable shocks and you got it.
FWIW, your sixty and ET seems off, slow.
Old Nov 15, 2012 | 10:18 PM
Justinktm's Avatar
im only launching at 1800 i cant really launch much higher or i spin im waiting to get a rear end under the car so it can hold a wrinkle wall and then ill be getting some good times =)
Old Nov 16, 2012 | 03:36 AM
lemons12's Avatar
Unless your using a trans break launching higher isn't going to do much for you, might hurt the 60 times. some converters liked to be flashed, some slack taken out, some to the breaking point. Either way its not going to be some huge massive 60 gain.
Old Nov 18, 2012 | 02:12 AM
Justinktm's Avatar
since the track is closed for the year illl most likely have a rear end under the car next year so i can finally put some rinkle wall slicks on her and see what she really has !!
Old Nov 18, 2012 | 09:51 AM
  #32
Cra-Z Larry's Avatar
You don't need wrinkle wall slicks to pull the wheels up!! You really need some susp. work and a good set-up! With your mods that car should be down to 11.5s Check Drag Results, a friends bolt-on car just went 11.98 and 1.59 60' at Atco last week!! I'm cam-only (and a small one at that) and my best times are in sig. As for tires, you can't beat MT DRs, and I launch like Lemons12, 1000-1200rpm and flash the converter. Dead hooks at every track!!
Old Nov 18, 2012 | 11:23 AM
  #33
custm2500's Avatar
Ph.D. in HUBRIS
To pull tire or not pull tire is a massive topic and not something that can be said in one sentance.
If you need weight transfer the the more wheelie the better to keep weight out back. If that is the case then a wheelie is the only way to make that car be it's fastest.
If you can dead hook and don't need the entire weight of the car on the rear tires to do so then just lifting the tires a touch off the track for the first bit of track helps get you out of the hole.
In a perfect world every launch would look identical to all the big classes. Top fuel being king **** obviously. If you notice they(funny car especialy) pull the front tires 2-4 inches, carry them for 60-100 feet and set them down. That is the "perfect" balance of weight transfer and getting the front off the ground to reduce resistance.
Old Nov 18, 2012 | 01:34 PM
  #34
Dirty Vegas's Avatar
Find out why it is SO slow first. Tires aren't helping you. A true drag radial will get you closer to your goal. Here is mine when it was stock internal. A 1.53 60' should get you there.
Old Nov 18, 2012 | 01:51 PM
  #35
lemons12's Avatar
Why are people still talkIng 60ft times? I have seen cars cut 1.4 and not raise the tires, i personally was cutting 1.50s and not lifting, i have seen cars cut 1.6s and raise them 2ft in the air.
Old Nov 18, 2012 | 02:13 PM
  #36
lynx853's Avatar
I ran my Good years at 15, psi, I could launch around 1800 with them. Lower your PSI and hit them harder, it might get you to your goals of pulling wheel, without having to change anything else.
Old Nov 18, 2012 | 02:33 PM
  #37
Because pulling the wheels is a function of traction. Better traction = better 60'. Who pissed in your cheerios this morning?
Old Nov 18, 2012 | 03:06 PM
  #38
lemons12's Avatar
It is a function of how the suspension is set up and weight transfer.
Traction has nothing to do with it. Cars can run low 1.4s and dead hook not lifting and cars can cut high 1.6s and dead hook and lift them.
#hangover
Old Nov 18, 2012 | 04:04 PM
  #39
Old School Heavy
Traction has nothing to do with it.r
That is going a bit too far.
Old Nov 18, 2012 | 04:38 PM
  #40
lemons12's Avatar
Dead hooking is dead hooking.. Even the 60ft time has nothing to do with it.
I would love to hear why traction (granted you're hooking), or the sixty foot time has anything to do with it.
By Brett Foote | 2026-06-04 05:00:17
