Wolfe Adjustable Rear Spring Perches, Who's Running Them?
bfh to the area around the TQ arm, I am running Moser NON fabbed housing and Burkhart TQ arm. its a tight fit, but it nothing is hitting.
IDK if most of my pics I had in my build thread where with the 8" springs or not, I used to run 10" springs but never could get the car to sit low enough, but the 8" springs did just what I wanted with the car.
My floor took a lot of work to get it to sit that low, and I ran the stock fuel tank for a long time but I'm finally removing it because the rear end has almost rubbed a hole through it.
Ultimately I'd like to get the car to tuck more than where it's at in the pics below. Just need to find out what all is hitting and find a way to make clearance.
So far I have enough room/clearance to get the tires up into the wheelwell but I think the axle tube is hitting the 4" exhaust over the axle.
![](http://i34.photobucket.com/albums/d136/Bowties4evr/Tucking%2028%20Inch%20Slicks/009.jpg)
![](http://i34.photobucket.com/albums/d136/Bowties4evr/Tucking%2028%20Inch%20Slicks/010.jpg)
