Drag Racing Tech
Abs delete ?
Old Dec 25, 2012 | 02:32 PM
SPOOLED UP's Avatar
Default Abs delete ?
I need to install all new lines on my car. SO I figure why not install a proportioning valve on my car. BUt I need to know what size lines from the master to the pro valve and throughout the car?
I figure 1/4 line under the car to the rear with bubble flare= metric lines
Which line on the master goes to the pro valve? Rear?
Then the front lines get teed together from the front of the master? If so what size lines from the master out.
I figure the front lines to the brakes and the rear brake lines are 3/16 with bubble flared ends.
This sound right?
Pix appreciated.
thanks
Old Dec 25, 2012 | 02:58 PM
solidws6's Avatar
i run a strange manual master with a wilwood prop for the rear & an slp linelock on the front. all lines are 3/16" with no issues & streeted daily. if you plan on a linelock, do it now. it's a pain in the **** to redo everything.
Old Dec 25, 2012 | 03:14 PM
solidws6's Avatar
Old Dec 26, 2012 | 10:34 AM
Boosted Firehawk's Avatar
I thought under the car had a 1/4" line?
without a line lock, where does the prop valve go? To the rear of the master correct?
Old Dec 26, 2012 | 04:27 PM
solidws6's Avatar
not sure on under car lines. everything i did was 3/16". i cut & flared the factory lines above the motor mount. i run a manual master so it might be different from a power setup but my prop goes to the rear outlet.
Old Dec 26, 2012 | 09:40 PM
robsquikz28's Avatar
I think the under car is 1/4"
Old Dec 27, 2012 | 07:55 AM
loudblack97z71's Avatar
under the car is 1/4" I just replaced all my lines running to the rear due to corrosion. Now I am kicking myself for not removing ABS...
Old Dec 27, 2012 | 05:31 PM
lol ya the abs block is useless for racecar ****!
I thought I was right.
