Drag Racing Tech
It has begun...
Old Jan 11, 2013 | 11:24 AM
sweetbmxrider's Avatar
Originally Posted by orange88ls1s-dime
I got nothing.
It just sounded like he was on a quest for weight reductions with earlier posts. Normally someone with a twin turbo engine doesn't mind spending a couple extra bux for something unless they didn't know what they were getting into in the first place
Seems like how most build threads go on the internet You also have to factor in it being tigged if he opted weld in which not everyone has access to.
Old Jan 13, 2013 | 12:53 PM
MUSTANGBRKR02's Avatar
That and MS is not as meticulous to weld as far as overheating.
Old Jan 14, 2013 | 04:08 PM
98Camarod's Avatar
Thanks for the compliments. I got a few things done. I got the majority of the pieces painted. All I have left is the dash and the rear hatch piece. I washed the pieces with soap and water, dried them, then cleaned them with alcohol, sprayed them with adhesion promoter and then painted them with the duplicolor vinyl and fabric paint.
I got a little over half the carpet done because I ran out of paint. I pulled the backing off of the carpet as well. I would have weighed it in the box, but my scale needs a new battery.
I also found $2.77 in change.
Old Jan 14, 2013 | 04:10 PM
98Camarod's Avatar
I got nothing.
As for this comment, I have spent many extra couple hundred bucks on many parts of my build. I didn't see that I needed to do that on the carpet as of right now.
Old Jan 14, 2013 | 05:10 PM
orange88ls1s-dime's Avatar
I didn't mean the carpet, I was talking about the Moly cage. How fast is this car going to be? Mild steel only good for 7.50 and you probably will fly with TT setup
Old Jan 14, 2013 | 09:48 PM
98Camarod's Avatar
Definitely don't plan on ever going that fast. I'll be happy in the 8's.
Old Jan 15, 2013 | 03:06 PM
manfred717's Avatar
Looks good Rodney, I will be putting mine in shortly!
Old Jan 15, 2013 | 03:35 PM
98Camarod's Avatar
Thanks man, are you stationed up here now?
Old Jan 15, 2013 | 09:23 PM
manfred717's Avatar
I am stationed in Norfolk. Are you still in kings bay?
Old Jan 15, 2013 | 09:29 PM
MylesF7's Avatar
Nice progress!
Old Jan 16, 2013 | 06:03 AM
98Camarod's Avatar
My boat got moved up to va. Were in nnsy now. You should come by the house sometime. Send me a pm with your number and ill shoot you a text. I got a new phone and lost your number
Old Jan 16, 2013 | 10:33 AM
  #32
manfred717's Avatar
Alright, pm'ed
Old Jan 22, 2013 | 06:16 PM
  #33
98Camarod's Avatar
I got the driver seat mounted. I cut two pieces of angle iron and welded them to the floor board. I'll take a pic of the brackets when the seats out, but this the picture that I have right now
Old Jan 26, 2013 | 08:37 PM
  #34
98Camarod's Avatar
I welded most of the passenger plate in. Definitely need to grind some of it down and reweld it.
Old Feb 3, 2013 | 04:09 PM
  #35
98Camarod's Avatar
I finished up the passenger side plate and got a good bit done on the drivers side plate. I think I'm getting better at it.
Old Feb 4, 2013 | 09:19 PM
  #36
skeeter99's Avatar
pics of seat brackets please
Old Feb 6, 2013 | 07:55 PM
  #37
98Camarod's Avatar
I got a little bit more done. I was able to finish welding the driver side support plate. Here is a picture of the seat mount as well.
Old Feb 7, 2013 | 08:39 AM
  #38
skeeter99's Avatar
are u mounting the seat flush with the floor or up some
Old Feb 7, 2013 | 02:27 PM
  #39
98Camarod's Avatar
It's up some. My head is close to the top. If it becomes a problem, I'll move it down.
Old Feb 7, 2013 | 03:53 PM
  #40
JustAFooL's Avatar
What set did you o with?? I just finished my kirkey pro drags and opted to go with the racecraft brackets. Good to see your learning to weld though, if I knew how, it would have saved me the 200$ for the brackets..
