Drag Racing Tech
Roll cage questions.
Old Jan 14, 2013 | 07:23 AM
VandykeT/A's Avatar
Default Roll cage questions.
I'm looking at getting a roll cage for my Trans Am. I've seen a few cages where the rear points bolted/welded in through the speaker covers and I've seen a few where the rear points attached to the floor pan more toward the center of the car. I'd rather not cut the plastic in the back (don't trust myself to cut it) so which kits come with the contact points in the center. Also what are the better fitting cages the car still sees some street use. Thanks
Old Jan 14, 2013 | 09:05 AM
99french's Avatar
I went to MWC and had them install a 8 point with fixed door bars. The ones on the wheel tubs in my opinion don't have a good mount point the metal there is too thin. So I went with strength and safety which is also why I have fixed door bars. My wife at 9 months preggers could get in and out as well as my grandma and mother.
Old Jan 14, 2013 | 09:11 AM
5.3LJimmy's Avatar
Wolfe sells a kit with over the seat rear bars. Be aware that you need to remove the fuel tank to weld the cage to the floor there. I pulled a tank out of a car for a fuel pump upgrade that actually had holes burned though it because they did not remove it. He was extremely lucky that it did not ignite.
Old Jan 14, 2013 | 10:14 AM
RamAir95TA's Avatar
I have the Wolfe weld-in 6-pt cage with the bars that mount to the deck lid.
On an LT1 car the fuel tank is steel so there is MUCH less risk to burning through, so I left the fuel tank in the car. It was a pretty easy straightforward install.
For streetability with just about ANY 5+pt bar you just have to deal with either swingouts or low-slung bars. Personally I think that's half the fun.
Old Jan 14, 2013 | 01:38 PM
VandykeT/A's Avatar
What would you guys recommend the low slung or the swing outs?
Old Jan 14, 2013 | 02:24 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Be careful of some of the "low slung" door bars... To pass tech the side bars have to pass the driver between the shoulder and elbow and not have excessive bend. The bars that have excessive bends or go under the armrest are considered "pro street" and chances are will not pass tech/certify.
Give me a call... You know I have the best quality and prices!
Old Jan 14, 2013 | 06:46 PM
1BAD98LS1's Avatar
X2..absolutely no point in doing a cage if it wont pass tech. Also it your considering going faster than 10.0 at any time I wouldnt do swingouts... i had a 10pt chromoly cage put in mine without swingouts and its no biggie to get in and out and will pass for NHRA 8.50 cert
Old Jan 14, 2013 | 07:06 PM
BarneyMobile's Avatar
I was under the impression that swingouts were legal to 8.50.
Old Jan 14, 2013 | 08:44 PM
owentm3's Avatar
Swing outs are legal to 8.50. Personally I prefer solid door bars.
Old Jan 14, 2013 | 08:54 PM
1BAD98LS1's Avatar
Not exactly sure of the rule... but I know they are heavily looked at by tech inspectors as a "weak link" in the bar. The faster you go the more they look at what you got...
