Has anyone removed there HVAC through the firewall?
I am wanting to tackle getting my HVAC out of the car to lower my weight as much as I can before I start doing all my custom suspension/ dieting.
I see this bigass box poking out of the rear left part of the firewall. I am wondering....if I remove that, or cut it. Can I not just reach in and rip, break the **** out of whatevers in there and cover it up with the HVAC delete plate?
The goal is to leave my creak free, uncracked, dash right where it is if possible.
There is a couple of threads I found that were showing people doing this. I did mine inside the engine bay, but I kept heat. Let me see if I can dig them up.
Edit:https://ls1tech.com/forums/lt1-lt4-m...-heat-how.html
Here is the thread that I had saved. I used my die grinder to cut the box flush firewall, but kept the fittings for heat. If you wished to delete heat also, you MAY be able to break everything apart and pull everything through the huge gapping hole. I have not tried it though.
I also didn't want to deal with all of the BS from pulling the dash and interior apart. From now on, every one of the deletes that I do, that wish to keep heat, I will do this way.
If you want the whole hvac out...just pull the dash, it isn't very hard at all, took me 30 mins first time. I highly doubly that you could pull it all through the firewall
your gona be cutting and breaking it out, if you take it out into the engine bay hole. So you will mess up other things that will get bent, and loose, so the dash is gona be alot more messed up, and loose piece still in there. Then it you took the dash out and put it back.
All the little 7mm bolts tighten right back up, dont worry about that.
