Drag Racing Tech
Speedyws6 build thread
Old Feb 26, 2013 | 02:51 PM
SPEEDYws6's Avatar
Default Speedyws6 build thread
Everybody loves a build thread... I'm board so time to start my own I guess.
Here is what I am starting with. Basically a cam only stick car plus a little dope. It went 10.02 @ 137 about 4 years ago, and has been sitting since then with no rear end or transmission.
After four years the garage door broke and I was told the car had to be moved so that it could be fixed. So I called up Madman and ordered a fab nine housing making sure that the rear end would work with the Madman torque arm that the car already had.
We ended up with a Racecraft housing. Narrowed 3" per side if I remember right.
40 spline gun drilled axles
Stange Ultra Case
After a little paint we ended up with this.
I found some wheels and tires from a Tech member and this is what we ended up with.
Old Feb 26, 2013 | 02:56 PM
SPEEDYws6's Avatar
While sitting around waiting on parts and trying to figure out what was going to power this thing I decided some weight needed to come out of the car.
Old Feb 26, 2013 | 03:26 PM
SPEEDYws6's Avatar
I also removed the stock plastic fuel tank and the brackets under the floor that hold the tank. After so many years of running a 9" and trying to make the car sit low on 30" tall tires I had just about rubbed a hole in the stock tank. The new rear end was no different, so out came the tank.
A little previous history on the car... A 10 point cage and mini tubs were installed by Madman back when the car was running as a stick car. It came in at 3400 Lbs race weight with me in it (280 Lbs) while still running stock brakes front and rear and stock front suspension.
I placed an order with Racecraft to make some changes to the front end. Here is what will be coming.
Old Feb 26, 2013 | 03:44 PM
SPEEDYws6's Avatar
Then I came up with a great idea for the power plant. So I think!!! It's been at least three years since I even opened hp-tuners so I'm sure to be a little rusty. I also what to go turbo and I have only dealt with turbos on diesels, so I'm not very confident in my ability to keep a motor together.
So with that said I got this.
Old Feb 26, 2013 | 03:45 PM
mikh338's Avatar
man i love the parts everything is sweet, the black weld rts wheels look sick on your car also. how much was that madman rear setup?
Old Feb 26, 2013 | 05:24 PM
SPEEDYws6's Avatar
The rear end was pretty expensive... I do not remember exactly how much though. Thanks for the compliments.
Old Feb 26, 2013 | 10:39 PM
studderin's Avatar
wow nice setup
Old Feb 27, 2013 | 06:05 AM
MADMAN's Avatar
LS1Tech Sponsor
Nice build. Keep me posted!!
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 27, 2013 | 07:18 AM
SPEEDYws6's Avatar
I will be coming to see you hopefully sooner than later.
While you are in here I have a question. Have you ever had the rear shock bushings on the afcos turn to mush? Mine are like that weather strip goop.
Old Feb 27, 2013 | 02:48 PM
Turnin20s's Avatar
Looks good man, I can't wait to cut out my rear floor, yours looks damn good. How much weight did you save after adding the metal back in for the floor?
Old Feb 27, 2013 | 08:13 PM
1nastyss's Avatar
Nice build , what the bs on the rear wheels ??
Old Feb 27, 2013 | 08:50 PM
SPEEDYws6's Avatar
The rear wheels are 11.25 wide with 4.5 bs if I remember right. I went back and edited the post about the rear end width. It's narrowed 3" per side.
I'm going to guess I cut about 30 lbs out of the back of the car. There was a pretty beefy battery tray that I had fabbed up to put the battery in the spare tire well that was also removed so it may have been closer to 40 lbs.
Old Feb 27, 2013 | 09:52 PM
Blackpanther99's Avatar
This is a good build thread. What turbo are you planning on running?
Old Feb 28, 2013 | 06:00 AM
MADMAN's Avatar
LS1Tech Sponsor
Give me a call. I can get you some new ones.
__________________
225-343-9029
Old Mar 1, 2013 | 05:27 PM
Reject's Avatar
^^ nice!
Old Mar 13, 2013 | 09:36 AM
SPEEDYws6's Avatar
Still up in the air right now... But it will be a t4 for now.
Old Mar 13, 2013 | 10:00 AM
SPEEDYws6's Avatar
Got a bunch of parts in, but I have been too busy to bother bringing the car back to the shop. I may work on it this weekend but I still don't have my reacecraft spindles so it would be pretty pointless.
Anyway, everybody LOVES pics....
I went with a Huron Speed hot side and cold side. When I first ordered the kit I did not have a welder so I thought I was saving a little money buying a pre fabbed kit, and then a few weeks later I purchased a welder anyway.
I'm in the process of selling the F1A that I planned to put on my firehawk, the HS turbo kit will eventually make its way onto that car.
The cam is a Speed Inc TU1 that will also end up being reused when the firehawk gets turbo action.
I got a little excited opening boxes and sliced my knuckle open on a staple. LMAO I felt like a kid at Christmas.
Strange Brakes for the rear
Strange 3rd gen brakes for the front
The RC front end requires a motor plate so while I was on the phone with Madman I had him send me one.
Old Mar 14, 2013 | 09:16 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Kick A$$ build! You are in great hands with Madman!
Coach
Old Mar 14, 2013 | 10:14 AM
SPEEDYws6's Avatar
Coach
You probably don't remember but we met a few years ago at Pine Valley Raceway.
Old Mar 14, 2013 | 07:45 PM
studderin's Avatar
thats the parts I want. congrads
