Drag Racing Tech
How does this layout look?
Old Mar 9, 2013 | 08:50 AM
Taubr Unit's Avatar
Default How does this layout look?
I'm more of a fab guy then a wiring guy so don't bust ***** too bad. I'm in the beginning stages of wiring my car for drag/street so pretty basic job. As my base does this look ok? Iv seen so many different ways to wire these 3 together and this is what I have in mind. Good, bad or what should I change? Thanks.
Old Mar 9, 2013 | 08:53 AM
Slowhawk's Avatar
LS1Tech Sponsor
Where is the shut off?
Old Mar 9, 2013 | 09:11 AM
Taubr Unit's Avatar
Ya forgot that in the pic, its inline of the main power run, about a foot from battery. So it goes from battery, to cut off, then continues to dist bock.
Old Mar 9, 2013 | 10:51 AM
green94z's Avatar
Have to run the alternator to the battery or disconnect
Old Mar 9, 2013 | 11:36 AM
Taubr Unit's Avatar
That sucks, that makes me run another wire all the way back to battery. Fail.
Old Mar 9, 2013 | 12:13 PM
Orange99Z's Avatar
If the alternator wire isn't on the battery side of the disconnect, the car will keep running after you shut the switch off. I also think you'd want bigger wire going to the starter. 4ga. should be ok for the alt. wire though.
Old Mar 9, 2013 | 12:50 PM
TPIIROC's Avatar
Yeah I used four gauge for the alt an zero gauge for battery cable
Old Mar 9, 2013 | 04:35 PM
Doug G's Avatar
Try this one from a buddy
I didn't use fuses or breakers, didn't run ground to front, and did use 0guage wire....4g is too small and I had issues with 2g.
Old Mar 10, 2013 | 10:14 PM
xpndbl3's Avatar
when you buy all the wire i'll just stop by jerry and show you how its done
I'll just need a complete single turbo setup, in exchange lol, let me know when you knock it out haha.
Old Mar 10, 2013 | 10:52 PM
Taubr Unit's Avatar
Whenever u wanna come wire Steve be by guest!! I'd MUCH rather build a turbo kit then wire!!
