Need help on gear and tire size
Fixing to buy tires for the track and need to know if a 26" or 28" tire is what I need. Also I'm looking at a gear change. I currently have a 3.50 rear gear because I had originally planned on doing more street driving plus I had a smaller cam in mind when I bought the rear end. I was thinking either 3.73 or 3.89. Car is NA and should be putting 550hp to the ground maybe a little more. I haven't weighed the car yet but I'm shooting for 3000-3100 by the time I get it to the track.
If the car works like it should, and makes the power you're claiming, there's no reson it shouldn't trap close to 130mph, and have power at 7k rpm. If it were me, I'd probably go with a 3.89 and a 28". That will leave you with a little room just incase you do trap higher than I estimated.
In all honest I think you could get away with a 4.11 and a 28" tire tho.
