Drag Racing Tech
Help me figure this out *broken driveshaft*
Old Apr 6, 2013 | 11:13 PM
DopeFedZ's Avatar
Default Help me figure this out *broken driveshaft*
So I went to the track last night and tried leaving on a 300 shot and these were the results. What I think is the cause are the u joints. The driveshaft was pretty beefy but I don't really remember being specific about the u joints when I had the driveshaft cut and balanced. Maybe I forgot to mention it would be used for a racing application . I'm going to get a new driveshaft and solid u joints is this something I'll have to keep worrying about or do do I need to invest in a progressive? Couple of weekends ago I left on a 200 and everything was fine.
Just trying to determine if I need to leave on less gas or if the u joint was just the culprit and if a heavier duty one will rectify this problem.
Old Apr 7, 2013 | 07:18 AM
Doug G's Avatar
I think a solid non-greaseable joint may help but not a 100% cure. Got to have a weak link somewhere I guess and a U-joint is cheap/easy fix compared to a rear.
Swap U-joints and try 250 ???
What size joint is it ? 1330,1350 ???
Old Apr 7, 2013 | 09:02 AM
Kingsize's Avatar
Has to do with the poor casting quality of the stock 1350 joint, + the use of a greaseable joint in your application.
Pick up a high quality casting, solid, non-greaseable u-joint like the ones Mark Williams sells. Be sure and pick up billet steel caps as well.
Old Apr 7, 2013 | 01:39 PM
MUSTANGBRKR02's Avatar
Sucks to see that be ause that car was leaving hard too. Lol
Old Apr 7, 2013 | 05:35 PM
custm2500's Avatar
Ph.D. in HUBRIS
U-Joint or bumper was going to need replaced on that launch I think.
How much power are you making with out the juice? The tottal power will help decide if you need stronger joints or a differant solution.
Old Apr 7, 2013 | 07:24 PM
DopeFedZ's Avatar
It makes 520 without the nitrous.
Old Apr 8, 2013 | 08:44 AM
slow67's Avatar
Gingervitis Addict
I would get one build by someone who builds racing driveshafts (like Denny's).
Old Apr 8, 2013 | 05:32 PM
Vexzer's Avatar
Shiny area on the fracture might indicate it had been running cracked for a while before it failed.
