26" tire vs 28" tire
Hey fellas, need some choosing a tire here. Was all set to buy some M/T 3055S 28" Stiffwall Drags for my 15 x 10 Weldstars for my next track outing. But after sifting through some of the threads here I'm starting to wonder if that's a little too much tire for being N/A and that I could make do with a 26" tire. The 3053S I would assume. Would the car be happier on 26 or 28?
Stock T56, MWC Fab 9 with 4.11s in the back shifting at roughly 6800 RPMs. I'm hearing the 28" might help my launch over the 26" but I really don't think I have that much power to overpower the 26" tire. I've read that Hoosier makes a 27" tire, but I really hadn't considered that tire just because I was sold on ET Drags. Recommend me a tire! Thanks.
![](http://i156.photobucket.com/albums/t3/SweeTbone346/BestGraph.jpg)
im right around the same power as you just more torque and im in the same boat. ive been going back and forth between a 26 and 28" tire. a lot of guys say the 28 will hurt out of the hole but from a roll it would be better. i raced my buddy in his 01 ss with 4.11s on a nitrous tune making 400whp and had 28' tires vs me in my 440whp car with 4.10s and with a very large passenger and iron block while on a 26" tire and he was door to door with me til end of 4th. i currently have 28" et street radials on my darkstar wheels sitting in my house because i cant decided to put them on or not(i dont have my nitrous hooked up yet). ive been worried about it hurting my car in n\a form.
28 should have more traction, but you need to gear for them. 26 work too, you can go fast (9's 1.3s, wheelies) but some guys race in worse track prep so like 28. Use what gears works so your at a good rpm thu the trap, 6500, 6800,7000, ect.if you want to run fast. And thats better for the car too, then running a bigger tire and less gear (28s with 410s, under 500hp ect, NA so your only gona trap 120-130s. To get the clutch out and not bog and pull the motor way down under 4K. thats harderd on the clutch, the shafts and gears in the t56, Ujoints. lots of info on this
cliff notes
26s with 4.10s
28 with 4.56s
---------------you need to work backwards for whats gears, I stole this chart I did off this thread
https://ls1tech.com/forums/drag-raci...-truecrap.html
I looking at the gear/mph chart on http://www.f-body.org/gears/
My 28/10.5/15S ETdrags Do think I put them in has a 29.0 tire, I think thats close to what there going in my car. II know on my 28.0 DR that don't grow I can tell its more RPM. What dose it look like for your trap/rpm for you guys on that tire. 29.5 even 30.0? you do have to clearence about 1inch around
RPM-MPH........../ 29.0 /4:30s
6000 120
6100 122
6200 124
6300 126
6400 128
6500 130
6600 132
6700 134
6800 136
6900 138
7000 140
RPM-MPH / 29.0/ 4.56
6000 114
6100 115
6200 117
6300 119
6400 121
6500 123
6600 125
6700 127
6800 129
6900 131
7000 132
cliff notes
26s with 4.10s
28 with 4.56s
6000 120
6100 122
6200 124
6300 126
6400 128
6500 130
6600 132
6700 134
6800 136
6900 138
7000 140
6000 114
6100 115
6200 117
6300 119
6400 121
6500 123
6600 125
6700 127
6800 129
6900 131
7000 132
t56,4.10
LEFT 26 ETdrags RIGHT 28s
(27"at speed) ...(29 at speed)
RPM MPH MPH
6000 118 126
6100 120 128
6200 121 130
6300 123 133
6400 125 135
6500 127 137
6600 129 139
6700 131 141
6800 133 143
6900 135 145
7000 137 147
4.10 gears with 26s
with 28s ![Sleepy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_zzz.gif)
FYI
1st time out after the cam I bought a set of 28/10.5stiff cuz I read it was the tire to run on here. I had a S60 with 3:73 gears. went a 11.7@121 on stock z28 wheels
put the race tires on, Car just bogged bad, and pulled 4th about 3-4 car lengths form the finsh??? ran 11.5 @ 120 or somthing?? ended up just leaving it in 3rd and tagging the limiter @7K a few times. and it went faster. Changed to more gear after, car drove alot better on the street (could use 5th and 6th around town) MPH better, 60' alot better, better ets with that.
id only run 28 with 4:56s, or 4;30s if your gona spray it a little.
RPM MPH MPH
6000 118 126
6100 120 128
6200 121 130
6300 123 133
6400 125 135
6500 127 137
6600 129 139
6700 131 141
6800 133 143
6900 135 145
7000 137 147
4.10 gears with 26s
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
FYI
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
dead hook, or bog?
did you ride out 4th, and see 120 is only like 5700. Or the car will go 135+ before 6500. the track is too short to get there.
28s with 4:10s
3rd and 4th
5000 81 105
5100 83 107
5200 84 109
5300 86 112
5400 87 114
5500 89 116
5600 91 118
5700 92 120
5800 94 122
5900 96 124
6000 97 126
6100 99 128
6200 100 130
6300 102 133
6400 104 135
6500 105 137
6600 107 139
6700 108 141
6800 110 143
6900 112 145
7000 113 147
dead hook, or bog?
28s with 4:10s
3rd and 4th
5000 81 105
5100 83 107
5200 84 109
5300 86 112
5400 87 114
5500 89 116
5600 91 118
5700 92 120
5800 94 122
5900 96 124
6000 97 126
6100 99 128
6200 100 130
6300 102 133
6400 104 135
6500 105 137
6600 107 139
6700 108 141
6800 110 143
6900 112 145
7000 113 147
28s with 4:10s
3rd and 4th
5000 81 105
5100 83 107
5200 84 109
5300 86 112
5400 87 114
5500 89 116
5600 91 118
5700 92 120
5800 94 122
5900 96 124
6000 97 126
6100 99 128
6200 100 130
6300 102 133
6400 104 135
6500 105 137
6600 107 139
6700 108 141
6800 110 143
6900 112 145
7000 113 147
