lightweight rotors oe replace
I've been trying to find the weight difference for the street/strip setup. I've read that its about 38lbs savings with their race version. I'd like to hope the street version saves atleast 20lbs
From what I understand if I do a LS brake conversion on my LT1 car it saves about 10# over my junk that doesn't stop for crap anyway. If there are ways to make it lighter yet it's even more of a bargain. Thanks for those that chime in with ideas, really, thank you.
Ive drilled the hats on steel rotors between the lugs before to lighten them. Can be done on the rear also. Most wheels never touch there anyway.
Same can be done for the hub/axle
And although it seems weird to say.....but learning how to brake. This gentle slow down that most all do from high speed is wrong. It puts heat in the rotor and pad then it just glazes them. You have have to come it on the brakes hard and smooth. Get that initial speed knocked off....cause with that speed is heat. Utilize the rotor/pads initial coolness then it's not a struggle for it later in the braking run to be effective.
