Drag Racing Tech
Need 60ft help Video
Old May 19, 2013 | 04:59 PM
stmz28's Avatar
Default Need 60ft help Video
The car has full bmr front and rear suspersion long tq with ajustable mount in the front with it mounted in the hightest spot now and rear drag bar. Qa1 12 way adjustable shocks 275 front springs and stock rear springs. The race weight is 3740 with driver the car has never been scaled. Best 60ft is 1.50 on trans brake @4500rpm best foot brake is 1.54
Stock bottom end lq4
afr205 heads with ls9 head gaskets
Brute speed blower cam
edelbrock victor jr intake
procharger f1a 10psi with aster bracket 5inch pulley
accufab 4150 throttle body
Extreme Velocity carb hat
procahrger blow off valve
cxracing intercooler
qtp headers
127lbs injectors
th400 trans circle d converter
9inch rear 3.50 gears
pump gas no meth
650rwhp 564rwtq
28/10.5s mt slicks
Old May 20, 2013 | 03:05 PM
SoundsZ28's Avatar
Love the car. Imo I believe it needs more gear
Old May 20, 2013 | 04:49 PM
stmz28's Avatar
With the gear and tire size i have now i am going through the traps at 6200rpm and the car makes max power at like 6200rpm.
Old May 20, 2013 | 05:08 PM
nmass399's Avatar
From what i can tell the car is bogging out of the hole and its picking the front end up too easily. Looks like if it did not bog it would do a crazy wheel stand. If you can log it and see what the rpm's are dropping to when it comes out of the hole, i would do that.
Old May 20, 2013 | 06:08 PM
Bowtie316's Avatar
If it were mine I would stiffen up the rebound on the front shocks and possibly have the converter loosened up. I didn't see what it stalled at.
Old May 23, 2013 | 02:17 PM
stmz28's Avatar
4500 stall. I put on a 2 step and tighten up the front shocks trying to go to the track this weekend and try it out
Old May 28, 2013 | 12:28 PM
stmz28's Avatar
Went down the track over the weekend. I ended up getting a cut in the tube on one of the slicks so i had to try out my drag radials goodyear 295/55/15. The best 60ft was 1.501 but only got 3 runs so have to try another day.
Old May 28, 2013 | 04:38 PM
03supercobra's Avatar
Ageed, you can tell the car doesn't come alive till later on. I'd try more gear and tighten up the front shocks.
