Drag Racing Tech
Nitrous set ups ?
Old Jul 27, 2013 | 06:31 AM
Mac 2002 SS's Avatar
Default Nitrous set ups ?
I'm thinking about installing a 100/150 shot on my car. My concerns are that I still want to stay on a 26 inch tire. My car has heads,cam,ss4000,and 3.73 in da'rear. Normally , I race in "D" running NA. I was wondering would I run in "Overdrive" if I were to spray my car ?
Also wondering would a progressive programmer be better than me just hitting the button in second gear ? I still have the stock rear and my car cuts 1.5's all day now NA. Thanks in advance .
Old Jul 27, 2013 | 02:21 PM
TurboStangJON's Avatar
whenever I raced my 4L60E I ran with the shifter in OD but the car never actually went into OD. Don't know if that was the correct way but I never hurt the trans or even had it rebuilt. If a progressive is in the budget then I'd go that route. It's nice being able to slowly ramp in the power especially when running on a less than stellar surface. The classes that allow progressives are always faster if they have similar rules/setups.
Old Jul 27, 2013 | 11:44 PM
1320Chicken's Avatar
What rpm are you crossing the traps at now? What's the shift point and rev limiter set at?
Old Jul 28, 2013 | 12:32 AM
My car is shifting at 6700 and rev is set at 6800. I have no idea what rpms the car is crossing the traps at ,but I know it wouldn't be enough to race my car in "D" with a 100 shot with those 26 inch tires I have on her.( ET Street DR's)
Old Jul 28, 2013 | 12:39 AM
Yeah, that progressive controller does sounds nice. Like you said, slowly ramp the in the power thru the entire run. I'm doing more research on that progressive controller , but I'm sure it has it pros and cons with it too.
Old Jul 28, 2013 | 01:03 AM
nocooler's Avatar
100 shot and it'll be close depending on converter slip.
10% slip = 128mph @6800
5% slip = 134mph @6800
Set the window switch @ 6750 and let it eat it
Old Jul 28, 2013 | 01:08 AM
LOL!! With my luck....BOOM!! .
Old Jul 28, 2013 | 02:27 PM
I don't see many cons besides user error. I'll always have one unless it's restricted by a class.
Old Jul 28, 2013 | 05:03 PM
98 grmrpr's Avatar
x2 on the controller.
I did some research on this already and it seems the bigger guys are using the elderbrock unit. It is a nice billit piece and quite cost effective around $500.
With the controller though....... you want to beable to feed the nitrous in yes, but at the same time feed the full 100% in as quickly as your setup will allow to maximise ets.
Old Jul 28, 2013 | 05:28 PM
FIVEPOINT7's Avatar
Lingenfelter makes a nice controller. Does everything you could possibly want, and then some.
