Drag Racing Tech
Track rule on hoods?
Old Nov 23, 2013 | 09:54 AM
1BAD98LS1's Avatar
Default Track rule on hoods?
Is there a rule that says you can't run down the track without a hood? Or does that just depend on the track or the event your running at? I'm guessing if you have a filter of some sort over your TB/Carb it shouldn't be a big deal...right? Let me know if any of you know or have this experience before I try and do it LOL Going to be racing mostly in Maryland btw...
Old Nov 23, 2013 | 10:24 AM
02 z/28's Avatar
No hoods}happens all the time here in Michigan.
Old Nov 23, 2013 | 04:03 PM
trans2000am's Avatar
hey now, dont make fun of me not my fault my car doesnt like hoods
to answer you question all depends on the track at milan i was able to run without a hood but when i called up us-131 i was told no
Old Nov 23, 2013 | 04:08 PM
high impact's Avatar
Depends entirely on the track rules. Most tracks require a hood.
Old Nov 23, 2013 | 04:11 PM
Murd450's Avatar
Check the nhra rule book . I've run with out a hood but had to tape up the back of the air filter ( carbed 83 Z ) so the air flow wouldn't suck the fuel out of the carb
Old Nov 23, 2013 | 04:19 PM
Murd450's Avatar
I don't know if you can make it out , but the tape on the back of the air filter with out a hood is NHRA legal
Old Nov 23, 2013 | 07:28 PM
1BAD98LS1's Avatar
I have an outdated 08' NHRA rulebook that I got just so I could get legal specs for my rollcage but it doesn't say anything about hoods, only hood scoops and their legal heights.
Old Nov 23, 2013 | 07:54 PM
Doug G's Avatar
I thought I read the without a hood you needed an air filter
Old Nov 23, 2013 | 07:58 PM
Murd450's Avatar
With out a hood you need an air filter with a closed back . Using tape to close it is acceptable . Went over this with track officials at Lebanon valley when my hood flew off on my first TT pass
Old Nov 25, 2013 | 04:04 PM
1BAD98LS1's Avatar
Where are all you east coast racers...throw in some input
Old Nov 26, 2013 | 06:49 PM
11SECSS's Avatar
I've seen them run without them at VMP and RICHMOND but cant say for sure about MIR.
