Drag Racing Tech
'93-'97 V6 Rear Springs Info
Old Jan 23, 2014 | 06:37 PM
RENE'S RAGE's Avatar
Default '93-'97 V6 Rear Springs Info
Finally went to the local Pull a Part.
Took rear springs off 3 different V6 cars.
'89, '94, '95.
All were 15" long. Coil diameter average was .398".
My WS6 springs are 14" long and .439" diameter.
Old Jan 23, 2014 | 07:14 PM
StangEaterSS's Avatar
Mine are from a 94. Work great. 1.34 60ft w qa1 single adj.
Old Jan 24, 2014 | 06:49 AM
Ed Wright's Avatar
9-Second Club
The 3rd gen V6 springs I measured were all smaller wire than the 4th gen springs I measured. Should be, they are lighter cars.
Old Jan 24, 2014 | 01:32 PM
ragtopz28's Avatar
I just went a pulled two sets ('89 & '91). Plan on cutting to achieve desired height and will probably sell the others. PM me if your looking for a set.
Old Jan 24, 2014 | 01:59 PM
What did they measure?
Old Jan 24, 2014 | 02:14 PM
ragtopz28's Avatar
exactly 15"
Old Jan 24, 2014 | 02:18 PM
Did you measure the diameter?
Old Jan 24, 2014 | 02:22 PM
ragtopz28's Avatar
Only had a measuring tape w/me, but appear to be the .398 you stated in your first post. Both sets were in great shape (for 20+yo) and had the factory sticker still on.
Old Jan 24, 2014 | 04:38 PM
Ed Wright's Avatar
9-Second Club
I took dial calipers with me when I went looking for springs. Softer the better. You only want enough spring to hold the car up. Much different than a road racer. Not as big a deal for lower powered cars. They are easier to hook. Pass 500 at the tires and you start to see the difference in some of this stuff. Hook it then, and you have to start worrying about keeping the front end down. LOL
Old Jan 24, 2014 | 04:51 PM
ragtopz28's Avatar
Yeah, I'm only 479 @ tire (for now). Gonna throw these in and see how it sits. Next is Strange SA w/300# springs front, then cut rears to get stance I want. Eventually wanting to get her to leave like a gator on a coot.
Old Jan 24, 2014 | 05:58 PM
Ed Wright's Avatar
9-Second Club
That is too much front spring! No more than 275 lbs. I have. 250 in mine right now.
Old Jan 24, 2014 | 06:26 PM
ragtopz28's Avatar
You think? Its a full weight street car, not a race car
Old Jan 24, 2014 | 06:36 PM
Ed Wright's Avatar
9-Second Club
AC and everything? 275. Every 25 makes a difference.
Old Jan 24, 2014 | 07:01 PM
ragtopz28's Avatar
Only weight reduction is light-weight battery and no sway bar. +adding roll bar (65#).
Old Jan 24, 2014 | 07:16 PM
Ed Wright's Avatar
9-Second Club
But the roll bar is not up front. 275. Already bought the front shocks?
Old Jan 24, 2014 | 08:37 PM
ragtopz28's Avatar
Have not bought shocks yet. Just trying to make clear this is a full weight+ car. And I want it to ride decent on the street. Another words the best street/strip compromise I can muster. I appreciate your input. Currently running on DMS lowering springs and stock deCarbons lol. Wanting to work on the 60' to get my 10 sec pass (traps 125 so I know it in her).
Old Jan 24, 2014 | 08:48 PM
Ed Wright's Avatar
9-Second Club
I drove mine on the street when it was a full weight street car, with a roll cage. AC, radio, etc. Street driven low ten second car. Pulled the exhaust, AC , and put some real slicks on it & put it in the nines. Had double adjustable QA1 front shocks. Got to the track and set both ***** for 1.31-1,32 60's. Got through, changed front shock settings, drove it back home. Between the shocks & springs it rode better than ever. No issues at all.
Old Jan 24, 2014 | 08:56 PM
ragtopz28's Avatar
I drove mine on the street when it was a full weight street car, with a roll cage. AC, radio, etc. Street driven low ten second car. Pulled the exhaust, AC , and put some real slicks on it & put it in the nines. Had double adjustable QA1 front shocks. Got to the track ad set both ***** for 1.31-1,32 60's. Got through, changed front shock settings, drove it back home. Between the shocks & springs it rode better than ever. No issues at all.
That's what I'm talking about!! Do you not think the Strange SA's will suit my needs. Currently @ 1.66 on the motor (not hitting 100 shot til 50-60' out to baby the 10 bolt).
Old Jan 24, 2014 | 09:18 PM
Ed Wright's Avatar
9-Second Club
Strange makes very good shocks. That is what I have on the rear.
I don't know how their single adjustables work. Does it change both extension and compression? If so you do not want that. You want them firm on compression. You want to adjust how easy they come up. I, nor others I race with, have to mess with compression once it's set.
AFCO DA shocks are great, but they put the damn upper adjuster (controls extension ) where they are too damn hard to reach. Most guys have to jack it up, and turn the tires to full lock each way to reach the damn ****. Compression **** on the bottom. The QA1 DA has both ***** at the bottom. Shops that sell AFCOs bad mouth the QA1s, my car worked just as well, and ran as fast with both. QA1 also makes a SA shock that only adjusts extension, stays firm on compression. Called "R Series", probably all you need for what you are doing. If the Strange works that way, they should be fine. When I has SA shocks that adjusted both ways at once when I got it soft enough to hook on drag radials it bounced up & down like a '52 Buick. LOL
Old Jan 24, 2014 | 10:01 PM
I did this on a full weight car with only front bumper support removed and battery in the trunk. you have to watch your ride height. my car was a bit lower than stock and that 275 spring is so soft that coming out of a burnout when you let off the headers would scrape the ground. stiffening up the front shock more to compensate the car wouldnt weight transfer correctly. if you like stock ride height, 275 prolly works. but just a heads up in my situation.
