Weld rts work with 5/8 wheel studs ??
As the title states, haven't been able to find much by searching , but is anyone running the weld rts wheels with 5/8 studs used with the alum. spacers ??? I'm about to order some 15x10 w. 5.5 bs for my narrowed rearend. Let me know what u guys have , thanks
you didn't look to hard, its right on their site:
>Surpasses SFI 15.1 Drag Race Drive Wheel Specifications (15" diameter only) & SAE J2530 Aftermarket Wheel (Street) Standards
>Center is available in polished or black anodized
>Wheel widths from 4" to 18" with a wide variety of back spacings
>Load rating of 1580 lbs per wheel (3160 lbs per axle)
>15" diameter bolt patterns: 5x4.5(114.3mm), 5x4.75(120.65mm), 5x5(127mm), & limited 5x120mm
>15" diameter wheel is designed for a 5/8" drive stud or a short shank mag style lug (except 5x5 bolt pattern)
>Center cap and valve stem included
>Made in Kansas City, USA
