What should it run?
I will probably be running on a 295/35/18 nitto invo tire
Stock 10 bolt
Stock suspension
m6
Stock Gears
~3600lbs with me in the car
Delaware
EDIT: Makes around 475 to the wheel
With 26 inch drag tires and 4.10s probably lower 12s at 112-114 if you are good at power shifting.
EDIT: I thought it had a LS1, I see in the sig it has a LS3, I have no point of reference for that engine.
FYI...last bolt-on car I helped with went 11.9 @116.xx.......on exhaust manifolds.
I would be happy with mid-high 12s with a street tire
My personal opinion is that with that setup even with street tires you should be in the 11's
with a sticky tire you should be high high high 10's at the very least an extreme low 11 assuming you have it setup right and are a good driver and racing in a DA of around 2000 or less...
Hopefully the 10 bolt doesn't go
[/QUOTYou'll probably be spinning so badHopefully the rear will be fine since you'll probably be spinning so bad lol
LOL. Maybe I should just wait until the weather gets warmer so I don't run a 14 in the freezing cold and get myself down
