post# of runs before factory clutch failed
Mine went out at~68,000 miles. 13.0s at 114mph. That thing died a terrible death to, pieces of friction disc and one whole spring were found in the bellhousing. Screw you clutch.
Motorboater
killed the first one at 22K, prolly a couple dozen track passes in the low 13's, high 12's.
second stock one was pulled 10K later, had a TON of passes on it, prolly couple hundred, all on drag radials, all mid 12's(on motor) and a couple dozen with a 200 wetshot on top of it. was getting worn but was still ok when pulled out.
