Drag Racing Tech
need to get heat out of the engine bay
Old Jun 8, 2014 | 09:35 AM
Ryans_pewter_ss's Avatar
Default need to get heat out of the engine bay
I drove my car to the track Friday night, when I got there I took the hood off and the strut towers was so hot they would burn your hand if touched, engine temps were fine but i know it's not good with all the heat in the engine bay. I have the extended vfn sunoco. I'm wondering if I cut it back a good bit from the glass if it would let the heat out. Any suggestions?
Old Jun 8, 2014 | 10:12 AM
Jake the SSnake's Avatar
Can you shim the back of the hood up a little without it looking like crap?
Old Jun 8, 2014 | 10:28 AM
I doubt it, I've been looking and I'm guessing all I can do is cut it away from the windshield, I know on a full race car it wouldn't matter as much since they are for track only but I street drive mine so I need to get the heat out
Old Jun 8, 2014 | 10:36 AM
SoFla01SSLookinstok's Avatar
Another way is to get some heat extractors in your hood somehow.
Old Jun 8, 2014 | 12:13 PM
Wheelman916's Avatar
TruFiber makes a nice looking heat extractor hood for the 98-02 Camaro
Old Jun 8, 2014 | 01:34 PM
[QUOTE=Wheelman916;18257041]TruFiber makes a nice looking heat extractor hood for the 98-02
Thanks but I don't wanna change my hood really, I have the extended vfn, I'm wondering if it will help to cut it away from the glass
Old Jun 8, 2014 | 02:08 PM
studderin's Avatar
car looks great
hows the IAT, how do you have the engine getting air? doing that setup with a SV right now looking at ideas, for street driving. I see some guys trim the top of the cowl to the glass in a area cutout. some have run a lower air pan and seal it to the hood. some get air from the front of thecar and duct it back to the TB.
Old Jun 8, 2014 | 02:14 PM
Originally Posted by studderin
car looks great
Thanks! I need to extend the harness on the iat and get it down near the bumper where it can get cool air, the car started acting funny after it got heat soaked. Right now the engine just gets hot air, I need to do the air pan so it can get fresh cool air.
Old Jun 8, 2014 | 02:17 PM
studderin's Avatar
whats the intake setup? have any pics?
Old Jun 8, 2014 | 02:19 PM
studderin's Avatar
http://www.yellowbullet.com/forum/sh...d.php?t=468985
https://ls1tech.com/forums/drag-raci...r-4150-tb.html
Old Jun 8, 2014 | 02:38 PM
Old Jun 8, 2014 | 02:45 PM
Exactly what I need! Thanks a lot for the help! I think that will fix all my problems
Old Jun 11, 2014 | 04:23 PM
RobsZ28's Avatar
Cutting the back of the hood and adding an air pan is more for getting cooler air to the T/b and less about reducing under hood temps. The opening in the hood would be sealed off, engine heat would not be able to escape out that way. I don't think adding an air pan will help with engine bay temps, if you cut the hood and didn't use an air pan that might help.
Here are a couple pictures I got from 3Fingas of the way his hood is cut.
Old Jun 12, 2014 | 07:26 AM
Zmg00camaross's Avatar
Could cleanly cut out the slp grille. Provide some cooler air into the engine bay. Also trimming the hood would help I believe.
Old Jun 12, 2014 | 11:00 AM
blue99fbody's Avatar
why do that need it at the tb to monitor the air temps the motor is actually inhailing
Old Jun 12, 2014 | 11:16 AM
I'm gonna do the air pan and mount the sensor in it
Old Jun 12, 2014 | 11:17 AM
TAHOE5.3's Avatar
Have a look at this thread over on the Bullet. I think this would be your best bet.
Jeff
Old Jun 12, 2014 | 03:38 PM
studderin's Avatar
ya, the air into the TB> engine. and air in/out of the engine bay are 2 different systems for sure. the tb is for performance 1st. just bay heat unless you melting things or some real problem remember to look at the areo of the car and how that affect the ET/MPH too with that trade off off air in the bay.
before cutting the grill or any holes look at the other way air gets in the bay. The wheel liners are huge on that. they let air in but it has to have a place to get out (if the hood cowl is open). and the under side area of the front end, and the ride height. The lower the better
