Drag Racing Tech
Weight reduction list!!!
Old May 20, 2004 | 12:10 AM
  #241
lsx24's Avatar
How much did it cost from where? Was it a drop-in replacement? I ask because I have been told on another board that it was not a direct replacement. Thanks!
Old Jun 16, 2004 | 10:32 AM
  #242
CHRISPY's Avatar
The 98 tank is 18 pounds heavier than th e99 and up AFAIK.
I am really interested to see pics of the speed glass installed in a STREET car.
Anyone have pics of a fourth gen with this setup?
Old Jun 16, 2004 | 01:48 PM
  #243
CHRISPY's Avatar
Originally Posted by Reckless
New item for the list. Just pulled my Firebird headlights and weighed them. I first removed the metal skins that cover the lights. I will rig some brackets out of aluminum for those. Total weight was 19.5 pounds right off the nose
How did this work for you?
Old Jun 17, 2004 | 10:26 AM
  #244
Damage Inc.'s Avatar
Sweet Cheeks
What about the A.I.R. system delete on a 99 car. I know people remove the air pump and plumbing. Can the codes be deleted and how much does this all weigh?
Old Jul 4, 2004 | 09:25 PM
  #245
dogboy's Avatar
I've heard that a aluminum radiator can be 40% lighter than a stock radiator. I have looked thru all 13 pages of this thread and no one mentions anything about this. Has anyone compared the weights?
Any trick to changing out the fuel tank in a 98 for a newer plastic one.
Old Jul 5, 2004 | 08:42 AM
  #246
Sweet Cheeks
What about those aluminum radiators that Jay Billingsley sells. Are they lighter than stock? What about that fan assembly? Sounds worth while.
Old Jul 6, 2004 | 12:59 PM
  #247
aram's Avatar
The stock radiator is pretty light and aluminum.. most aftermarket aluminum radiators also hold a lot more water which would also add a lot of weight to the front of the car.
Old Jul 9, 2004 | 11:50 AM
  #248
Sweet Cheeks
Ok guys I got some weights for the list.
Bogart D10s from SJM:
15x3.5 - 9 lbs
15x9.75 - 11.5 lbs
Moroso DS2 Front tires 26/15 fronts - 12 lbs
M&H Cheater Slicks 26/15/11.5 - 21 lbs
Total weight 107 lbs.
Not bad considering my ZR1s and tires weighed in at 216 lbs!
Also, the wiper motor and mechanical assembley for them was 13.5 lbs.
TTT
Old Jul 10, 2004 | 03:02 PM
  #249
04BlackGmc's Avatar
I a really looking to get my 94 3.4 down around 3200 without driver. Also me being light help. I only weigh around 130..
Ill post some updates later.
Old Jul 21, 2004 | 02:34 PM
  #250
Sweet Cheeks
Quick question: What's that cylindrical canister (black plastic) tank right next to the coolant overflow canister? It's right by the horn on the passenger front. Can I take this out? It looks light, but hey, it's something.
Old Aug 1, 2004 | 09:23 PM
  #251
12secondv6's Avatar
https://ls1tech.com/forums/drag-racing-tech/21408-ques-about-part-i-could-remove-weight-reduction-but-consequences.html
Hope that helps
Old Aug 2, 2004 | 10:05 AM
  #252
Sweet Cheeks
Okay thanks a lot. HVAC is coming out with it then.
Old Aug 25, 2004 | 03:10 PM
  #253
JxxxOxxxE's Avatar
Anyone know the weight of a stock SS hood? I am switching from my stock Z28 hood to an SS hood. If the stocker is 50 lbs, like said, I would like to know how much is saved with the SS hood...
Old Aug 25, 2004 | 09:50 PM
  #254
Sweet Cheeks
If you're referring to switching from a stock Z hood to a stock SS hood, I'd say you'll gain a small amount of weight instead of shedding any. That is of course if the SS hood is stock and not fiberglass. Good luck.
Old Aug 26, 2004 | 09:34 AM
  #255
JxxxOxxxE's Avatar
I thought the stock SS hoods were fiberglass....?
Old Aug 27, 2004 | 01:10 PM
  #256
EdmontonSS's Avatar
The stock SS hood is fibreglass, but very high quality, very stiff, thick. I have it in my head the OEM SS hood weighs in at 55 pounds, I was thinking about going to a VFN fibreglass hood (13 lbs?) and those numbers are what's in my head....
Old Aug 27, 2004 | 02:47 PM
  #257
JxxxOxxxE's Avatar
Wow..scratch the idea of losing any weight if the stock SS hood actually weighs 55 lbs...
Old Aug 27, 2004 | 03:25 PM
  #258
Sweet Cheeks
Yup. I'd go fiberglass. The RK sport SS hood is SUPER light, but I hear has a few fitament issues. It's worth looking into if you're dead set on an SS hood.
Old Aug 29, 2004 | 12:03 AM
  #259
dogboy's Avatar
I did the swap and the ss hood is lighter. I didn't have a way to weight them but I remember reading in post that it's about 15-18lbs lighter.
Old Aug 30, 2004 | 09:26 AM
  #260
Sweet Cheeks
OEM to OEM, I find that hard to believe. I hope I'm wrong.
