Drag Racing Tech
Weight reduction list!!!
Old Aug 30, 2004 | 10:50 AM
  #261
dogboy's Avatar
Stock Z28 hood is steel, SS hood is fiberglass & composite, so I've been told??
Old Sep 12, 2004 | 05:05 PM
  #262
CHRISPY's Avatar
Just saw this (interesting)
Differential Weights of Accessories:
Item Weight (lbs.)
6-way power seats 7.9
Remote lock control 0.4
Power door locks 1.8
Power Windows 2.7
Remote trunk release 1.3
Rear floor mats 1.8
Body side mouldings 1.8
T-Tops 12.3
Fog Lamps 2.7
Rear defogger 0.4
Sunshades 2.7
Electric sport mirrors 0.4
Cruise Control 4.4
Auto Transmission 84.7 (with LT1)
1LE 7.0
Bose Speakers 7.0
AM/FM w/CD 0.4
Old Sep 12, 2004 | 06:59 PM
  #263
TheBlurLS1's Avatar
That's what she said...
you guys need to talk to some sprint car racers. i used to wrench on a guys car who raced in the world of outlaws (john bankston - beaumont tx). his car weighed 1040 lbs ready to race w/ gas and oil in it. oh yeah, it had 850hp
every single bolt you could find on the chassis was titanium w/ the head milled down and the center drilled out.
Old Sep 12, 2004 | 07:28 PM
  #264
Damage Inc.'s Avatar
Sweet Cheeks
Might as well launch a missle and strap yourself onto the nose. Ha.
Old Sep 24, 2004 | 06:57 PM
  #265
Jorday's Avatar
whooohoooo, lost over 50 pounds today by removing front and rear bumper supports, and some other misc. crap in the car. Also have the dynobatt and a set of bogarts on order.
Old Sep 24, 2004 | 08:10 PM
  #266
Sweet Cheeks
Now that's what the hell I'm talkin' bout! Ha!
Old Sep 24, 2004 | 09:07 PM
  #267
project98LS1's Avatar
Another good way to lose weight in case you hadn't though about it (kind of obvious), is going true duals, du,p before the axle, and being able to get rid of the cat-back system. I bet you could shave off a good 30 pounds or so. Just thought i'd try and contribute to the list.
Old Sep 25, 2004 | 05:47 PM
  #268
Jorday's Avatar
true duals with dumps before the axle...check
Old Sep 27, 2004 | 10:06 PM
  #269
Flawless02SS's Avatar
First thing I did was removed the spare tire and jack, I think you can shave 35 to 40 lbs. And then of course the back seats it's around 40 or 45 lbs.
Old Oct 8, 2004 | 06:40 PM
  #270
nyg215's Avatar
i have a problem with getting to my front bumber supports. the supports will not come out i had all of the bolts and push pins out that i could see but then i saw that the bumper is attached to the fenders and there is no way of getting to it.how did you get your supports out?????
Old Oct 9, 2004 | 01:33 AM
  #271
Sweet Cheeks
You have to remove the locking washers that are between the foam and the metal support. After that, it's cake. The whole process shouldn't take more than a half hour.
Drop the front fascia, it'll save a headache.
Old Oct 13, 2004 | 05:20 PM
  #272
does anyone know how much the stock muffler weighs?
Old Oct 25, 2004 | 05:16 AM
  #273
KimberWS6's Avatar
I can tell you too damn much after droping on my chest
Old Oct 25, 2004 | 09:36 AM
  #274
BADSZ28's Avatar
Most say about 50lbs. I am dropping mine this winter. I will post weights then.
Old Nov 2, 2004 | 01:33 PM
  #275
12secondv6's Avatar
When I went fomr an edlebrock cat back to SLP loudmouth I lost 21 pounds.
Current vehicle weight, 2900 EVEN! I had a helmet and a couple tools in the bird that day, so it should be under 2900's
Old Nov 28, 2004 | 08:19 PM
  #276
MakoLS1's Avatar
For 98' Cars.
-EGR... 15lbs
Thats all the tubeing, and like 3 or 4 various pumps and/or devices and a few rther heavy metal brackets. Mounted next to the intake, and most of it is under the drivers side head light.
Old Dec 14, 2004 | 03:23 PM
  #277
Nate_Taufer's Avatar
the factory catback setup weighs around 55 lbs with hangers. The TSP true dual setup for example weighs in at 34. So thats another 21 lbs. It's not the cheapest way but for around 20 bucks per pound with more lowend tq you're good to go.
I dont know if the 4th gens ever came with plastic door handles (maybe on the m6) but you could always swap the metal to plastic for maybe another few lbs for the all out racer. But then again maybe im just on crack.
Oh, and the dome lights.
Old Dec 14, 2004 | 05:02 PM
  #278
BADSZ28's Avatar
Actually, the TSP TD is much cheeper than replacing the cat-back and Y which is what that system replaces. And the total difference between a conventional Y-cat-back to a TSP is about a 40lbs difference or so. I went over this with another member who did this swap. I will see if I can find the thread.
Old Dec 15, 2004 | 01:13 AM
  #279
NLang's Avatar
Factory T/A headlight assemblies: 12.5-12.9lbs EACH.
Factory hood hinges: Just under 3lbs EACH.
Old Dec 15, 2004 | 03:04 PM
  #280
oh snap badz. i totally forgot to think of the y-pipe you wouldnt need with the td setup. I was just comparing catback to td. so you're saying factory y weighs another 19 lbs?
