Drag Racing Tech
Weight reduction list!!!
Old Sep 9, 2007 | 09:18 AM
  #401
XLR8N's Avatar
Default retard
Originally Posted by 05 GSXR 1XXX
dude you have to be ******* kidding. that poor car. it will never forgive you. how about making more power. cause its going to be embarrassing to get beat by a full weight car. thats is just ridiculous.
Old Sep 20, 2007 | 07:15 PM
  #402
Platinum WS6's Avatar
I got a wild hair today b/c my sub went out again and I am tired of putting money in a sound system..SO..I pulled out my amp rack which has 2 amps and a cap on it and also pulled out the sub. I went ahead and took out the monsoon amp which only weighs about 4 lbs but hey thats 4 lbs right? All together that weighed 71 lbs. The amp rack went all the way across the back and the sub box was VERY heavy including that Kicker L7 that weighs in at about 15 lbs by itself! Anyways it actually raised the back of the car up giving me some more ground clearance (which I needed)! So if you have a serious sound system in your car...take it out and save some weight!
Old Oct 13, 2007 | 11:29 AM
  #403
chrismorales75's Avatar
Don't forget to add struts to wallet mods, no upper control arm and a nice lightweight strut and small spring has to drop a good amount.
Last edited by Navy David SS; Nov 18, 2007 at 09:23 AM. Reason: no reason to quote initial post
Old Oct 20, 2007 | 02:37 PM
  #404
My 1998 Camaro's front bumper was 20 pounds, rear was 20 pounds as well, however I did not weigh them with the bolts. So plus a pound or so.
Old Oct 24, 2007 | 10:13 PM
  #405
GMmexican's Avatar
im thinking of deleting my ac, search didnt show anything..........anyone have any tips on how to do this, is it pretty straight forward? im also going to remove the ac belt
Old Oct 25, 2007 | 02:11 PM
  #406
It's all unbolt stuff however if you pull out the blower motor in the firewall you'll need a plate to block off the hole, everything else is pretty straight forward, unbolt and remove stuff.
I am not sure but everything has to be 50 pounds maybe more when you pull the a/c pump, brackets, condenser in front of the radiator, all the hoses, the blower motor, the ducting under the dash.
Also if you pull the blower motor you won't have a window defroster which is a bitch.
Old Oct 31, 2007 | 04:05 PM
  #407
98TADRIVER's Avatar
discharge the system first. disconnect all of the lines going to your a/c stuff. the condenser is easy to take out. take your whole airbox off (4 bolts) and pull the condenser out. there are 5-6 bolts holding the a/c pump in. theres 3 bolts up top and 2or 3 at the bottom. then you can easily pull your ac pump bracket off of the block, thats a couple bolts as well. drop your sway bar (only 4 bolts holding the sway bar to the brackets) to make it easy on yourself when it comes to pulling the a/c pump out. the evaporator or accumulator is that lil aluminum can lookin' thing, take that out and id just leave the other part thats in the firewall its only a couple lbs and u can lose that elsewhere and save yourself the trouble! hope this helps u!
Old Nov 4, 2007 | 08:08 PM
  #408
GMmexican's Avatar
I took everything off theres just one bolt on the bottom of the ac pump thats a bitch to get to, thats holding me up right now
Old Nov 7, 2007 | 01:53 PM
  #409
mini tubbing, I weighed everything I cut out to run 16" tub from fender lip, all of the metal and brackets were 49 pounds.
Went an additional inch so 17" tubs will weigh the rest and also weigh the metal I am putting back in.
Old Nov 11, 2007 | 04:57 PM
  #410
Matt D's Avatar
Retired Street Racer
It says wiper arms and motors are 6 lbs total, that is incorrect. They are easily 10-15 lbs.
Old Nov 11, 2007 | 09:37 PM
  #411
dlove's Avatar
stock hood 50 lbs
hinges 3 lbs each
latches 2 lbs
Old Nov 12, 2007 | 05:28 PM
  #412
Originally Posted by dlove
stock hood 50 lbs
hinges 3 lbs each
latches 2 lbs
What about the plastic bracing that holds the factory hinge and little rubber bump stop?
If you're running a pin on I would think you could cut those off as well but they don't look to be very much weight maybe 1-2 pounds for the 4?
Old Nov 14, 2007 | 12:03 AM
  #413
Anyone else weigh their seats, mine didn't match the weight listed on this post?
Old Nov 15, 2007 | 11:12 AM
  #414
dlove's Avatar
im not sure what piece you are talking about
the rubber bump stops add up to a pound
the metal bracket the bump stops and the shocks mount to probably add up to 4 pounds
Old Nov 15, 2007 | 11:15 AM
  #415
dlove's Avatar
the dash pad- piece infront of the dash on top
4.5 lbs
Old Nov 15, 2007 | 11:21 AM
  #416
Demonicbird00's Avatar
4.5 lbs
i was suprised at how heavy that was when i was in the process of taking the pass air bag out.
-brandon
Old Nov 15, 2007 | 12:52 PM
  #417
SO far I am at 56.5 pounds of metal I cut out/removed doing my mini tub job and I might cut out all of the inner factory fender, I am sure that would be at least 5-8 more pounds easy.
I'll weigh everything before I weld in the new plates and weight the tubs after I cut them to fit.
I am guessing a 40 pound savings.
Old Nov 17, 2007 | 06:29 PM
  #418
dlove's Avatar
each of my inner fenders came in at 5lbs
Old Nov 17, 2007 | 09:28 PM
  #419
Matt D's Avatar
Stock cloth power driver: 40lbs
Stock cloth manual passenger: 30lbs
Lightweight RCI aluminum race seat, cover, and bracket: 13lbs
Old Nov 18, 2007 | 12:27 PM
  #420
camaroslpss's Avatar
Default Frame horns???
Has anyone cut off their frame horns to save weight? The body shop was not able to salvage my drivers side frame horn. Anyone still have theirs and want to sell? Let me know asap, once I get this welded back on I can start installing body pieces. Thanks for the help guys!
By Brett Foote | 2026-06-04 05:00:17
