Drag Racing Tech
need help wiring power windows
Old Jul 14, 2014 | 05:59 PM
Taubr Unit's Avatar
Default need help wiring power windows
long story short, gutted entire car and now need to hard wire my windows. I dont need the pass side switches wired, ill control them from drivers side. Iv heard about running 4 relays, one for up, one for down and same for pass side motor, dont know if this is true or not? Its a '94z and heres the stuff im working with. One is the plug on the switch and the 2 plugs are the plugs for the motors....
Old Jul 14, 2014 | 10:53 PM
blue99fbody's Avatar
Man you screwed up if you ditched the factory door harness its so easy with the factory stuff its unreal and no unnecessary wires once u strip the other **** from the doors. Its literally clipping one wire and putting it to power and they work
Old Jul 15, 2014 | 12:35 AM
Blown06's Avatar
8 Second Truck Club
No relays needed. Google "reverse polarity"
Old Jul 15, 2014 | 05:49 AM
Taubr Unit's Avatar
technically i did but i have the harness in a box, i could go through it and find what i need. However with the pigtails cut off itll be hard to find especially not knowing what it looks like.
Taubr Unit's Avatar
will do, thanks
Old Jul 15, 2014 | 07:43 AM
shouldnt be hard to find it be the smaller harness with some heavy brown blue tan and black wires and a single small black box hanging off of it and should have a long flat plug that went to the steering column clip the brown wire from that and put it to power. connect your motor wires pigtails back and hook up the black ground and done
Old Jul 15, 2014 | 09:46 AM
RENE'S RAGE's Avatar
I sent you the info in a PM afew weeks ago.
It was titled Cheetah Shifter.
I'll resend it.
Old Jul 15, 2014 | 12:25 PM
Taubr Unit's Avatar
I thought I read it somewhere but was thrown off by the title when I was searching, lol. Seems too easy though, hope it all works that way, that would make my life easy!
Old Jul 15, 2014 | 02:14 PM
Trust me, I'm a Doctor!
Old Jul 16, 2014 | 10:36 PM
Taubr Unit's Avatar
Thanks Rene, your a god-send! Wired them up as posted and works like a charm! Easy as anything iv done so far, thanks again!
Old Jul 17, 2014 | 07:54 AM
I'm really not a doctor, I'm a lawyer.
Or maybe a Senator's son.
Glad you got it wire up.
Old Jul 17, 2014 | 10:31 PM
Mighty Whitey's Avatar
This is good info to know. I'm about to ditch the majority of my stock wiring and was worried about the power windows As well.
Old Jul 18, 2014 | 03:23 PM
JL ws-6's Avatar
Race your car!
I can tell you how I did it, get a dpdt switch. wire power to the center lugs of the switch, then tie the 2 sides of the switch together so polarity will be reversed when you hit the switch in one direction vs the other.
One set of wires to the windows, simply supply power to the switch center lugs. Fuse it for 25 amps, so if something shorts out it will pop the fuse. Done deal.
I put 2 switches under my seat on a bracket to control the windows, this way they are easily reachable, without trying to mount something in a carbon/flat door skin, and it's one less thing to have on the dash.
