Drag Racing Tech
Lock up switch
Old Nov 24, 2001 | 08:55 AM
cdm98z28's Avatar
Default Lock up switch
I've had a lock up switch on my car for almost a year and every time I try it at the track I lose about 2 mph. I hit the switch in second gear, am I hitting it too early. I'm using a Vigilante 3200 converter, and I'm happy with my mph. However, I'll take more if I can get more.
Old Nov 24, 2001 | 09:26 AM
jimbob's Avatar
Default Re: Lock up switch
Try it in 3rd, just about 5000 (95 mph or so), some guys go to 5500 if they have a real high shift point.
Caution: If you don't have enough gear to run high in your rpm band through the traps, then you'll probably loose mile an hour!
Example: My stroker go's through the traps at 6000+. If I lock up the converter I gain 1 tenth and 1 mile an hour. If I had taller gearing then I would kill shift extension by locking up the converter, to early (while it's still in the extension). Each combo is different, gear, hp, torque converter stall/extension and weight are some of the veritables.
Jim <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
GeorgeC's Avatar
I always got the best results manually locking my converter @ around 5000-5500 rpm or so in 3rd gear... I wouldn't manually lock the converter in 2nd. I would think that would almost bog the engine down when it made the 2-3 shift.
Old Nov 24, 2001 | 03:47 PM
Ls1 346ci SS's Avatar
yup, I have had mine and I have used it a couple of times on the street. i lock it up in 3rd around 5,000 rpm's. I wonder how I will fair at the track with the 3.73's and the moser 12 bolt. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 24, 2001 | 04:49 PM
Slow Z28's Avatar
hey that's funny, cdm98z28...
my name is Christopher Daniel Minnich and i own a '98 z28. you copying me? anyways, to help you out...
i was going 12.8's at 104mph, but when i lock it up at 5200 about(on the stock tach) in 3rd gear, i gained 2 tenths. went down to 12.6 @ 106mph, same day, one run after the other. good luck and hope this helps. i think that when you shift into third, the engine is bogging down with the low rpms from the gear drop.
Chris
[ November 24, 2001: Message edited by: z28kid98 ]</p>
Old Nov 24, 2001 | 05:39 PM
ONYXSS's Avatar
As said above, don't lock it until the top of 3rd. I've never locked mine at the track, except when I hit the switch by accident and made a full run locked, start to finish <img src="images/icons/shocked.gif" border="0"> <img src="images/icons/shocked.gif" border="0">
No wonder my trans is slipping!!
Old Nov 24, 2001 | 06:54 PM
cdm98z28's Avatar
Thanks for the replies. The car did seem to bog down slightly when it shifted 2-3. It just seems to me that locking up at 5000-5200 in third is so close to the end of the run, that gains would be minimal. I've heard of so many people getting .1-.2 sec and 1-2 mph, hopefully I'll be one of them once I try locking it later than I have been.
Old Nov 24, 2001 | 07:58 PM
So Slow's Avatar
I've wanted to find out how to wire a switch in on a 2000 model..Does anyone know of a site or could help me out wiring one up ?
Thanks..
Old Nov 25, 2001 | 10:09 AM
So Slow's Avatar
Anyone ??
