Maybe shooting for 10s soon
I'm thinking if I can eliminate that spin off the line, lower my 60' to at least 1.5, and throw some skinnies on the front that should land me some where in the 10.90s. Also the tire Im running is an ET Pro @ 18psi.
Any extra input would be appreciated!
Just pill the bitch up a bit.
It's no secret that a radial tire is both quicker and faster if you can dead hook it.
You said that you had very little issues with spin. With no other changes (increased launch rpm included), the car would show slower with a slick. Now, if you wanna dump the clutch at 5500 with the spray on, slicks will be your best bet.
Im guessing if I heat the tires up a little more it should make a difference. I know a slick would knock off a mile and hour or two on the big end but think I can get these to work. I mean x275 guys use em at double and triple my hp!
