Weather ?
humidity is water vapor in the air. The more water in the air, the more Oxygen is displaced - less Oxygen into the combustion chambers.
FOr best times, you want high pressure and low humidity.
Usually when I go to the track for an evening/night event, the humidity gets higher as the night goes on, although the temperature drops. So 1) does the humidity % go up only because the drop in temperature means the air can't hold as much water? and 2) is the increase in humidity offset by the drop in temperature? I'm assuming if what I said in 1) is true, then there is the same amount of water in the air, but the temp is lower, so the air is better as the night goes on.
Fact 2: Relative Humidity is the measure of how much water vapor the air can hold in relation to how much it is actually holding. relative humidity of 80% means the air is 80% saturated with water vapor. At 100%, the air cannot hold any more water vapor.
Fact 3: Ignoring other atmospheric effects such as evaporation, rain, etc. humidity will increase as temperature drops, since the air is not able to hold as much vapor per unit volume.
Fact 4: Once the temperature drops and relative humidity reaches 100%, you have reached "dewpoint" where water vapor will condense on any surface available.
So hopefully you can read these facts and see that the air is getting denser (Good), and the water vapor is not actually increasing per unit volume - the air is just losing its ability to contain the vapor as the humidity increases. If the humidity is high, hitting dewpoint is good for times since the amount of vapor in the air will also drop as the temp drops (but the track might get slippery!).
That being said, you would still ideally prefer cold temps AND zero humidity (i.e. a VERY cold dewpoint).
Bob
Meteorologist, one each.
Pilot? not yet - Might go for my license next summer... I did stay at a Holiday Inn last night though!
