Light weight wiring harness
Not hard at all, start by taking your fuse boxes out and go from there.
You will see all the connection plugs. There's a big black junction box that goes through the driver's side firewall, that's the one that will be a bitch. Once the wires go into that junction box you can't tell which wire is which on the other side. You will have to ohm them out. The wires don't change color but you may have 3 blue wires in and 3 blue wire out. You can't tell which blue wire goes to which blue wire.
Or you just leave the junction box and cut you wires at the box.
Just takes some time. Sure cleans up your engine bay.
Also thought about mounting some things on the glove box door and making slits for the wires to go through so when the door was opened it wouldn't pinch or stretch any wires. So many things can be done with the wiring if you have the time and patience.
And that is basically all wiring from the front?
Did you unpin the items you were not using anymore? I guess I need to just buy a spare harness and start this project.
So any more tips from people who have done this? Am I wrong in thinking I can buy a spare engine harness and follow all the wires to where they pin into the connector and un pin it and then with the wires I have left just unplug my current engine harness and plug the new one in?
Layout the complete harness and label BOTH ends of all wires. Then start marking PULL or STAY. From there it makes it an overall easier and cleaner process so you can buy replacement loom, sleeves, cable clips, etc. Then you pull them exactly like you said, unpin from PCM side and start working it out from there to the end. Clean up all grounds while you have it out.
