Few changes and few problems
Swapped mild 222/224 cam to a 242/248 aggressive cam, replaced stock rear end to a 12 bolt 4.88 and pulled out a good 100lbs in weight.
Good air it ran 7.30s and this weekend after the changes the best was 7.07. It's better in et but the 60ft stayed exactly the same. Couple other issues we noticed the abs light has been on since the rear end swap. In the burn out the line lock won't hold, staging it will roll after 2400rpm (before 2800) and it did vary in et quite a bit in one day.
Just thinking out loud.
