Drag Racing Tech
FMS Solid Roller Setup Madien Voyage@HRP
Old Jan 26, 2002 | 02:53 AM
GTS SS's Avatar
Default FMS Solid Roller Setup Madien Voyage@HRP
Yep, finally got the car done and took it to the track.....HRP that is.
Just made 3 shake down runs, didn't remove the exhaust, passenger seat or the air filter, just uncaped the cut-out.
Raceweight was 3550 lbs.
The motor is still 346 cid & the T-56 M6 tranny is still in there as well.
1st run: 11.37 @ 123.63 mph 1.739 60', left the light at 5000 rpm and being that HRP was hooking rather well I bogged the motor bad on that launch.
2nd run: 11.27 @ 123.41 mph 1.632 60', left the light at 6000 rpm this time, it hooked, the wheels came up, I freaked <img src="gr_eek2.gif" border="0"> , then gathered my thoughts and continued down the track.
3rd run: 11.06 @ 124.00 mph 1.530 60', left the line this time at 6500 rpm. It hooked, I went!
Still got some tweaking to do on the tuning but
I'm extremely please with how the car runs now, and especially how it leaves the line...straight, level, and wheels up in the air! <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Allan Futral of Futral Motorsports in Walker, LA. 225-791-9593, did all the work on the car.
Here's the list of what was done.
-FMS Solid roller cam
-FMS/Meaux ported LS1 heads 2.055/1.600 valves
-11.5:1 cr
-T&D rockers 1.7 ratio / Crane lifters, etc etc...
-Dry Sump Oiling system
-36 lb. injectors
-85 mm GM truck MAF
-Allan modified my G-Hann headers to make them into 2 step headers 1 3/4 ~ 1 7/8, then added a set of Dyna Tech 3" Drag collectors.
-FMS Custom 3" ORP & a 3.5" cut-out
-3.5" Mufflex exhaust
-PA Chromoly K-member & Lower A-arms
-V6 rear springs
-Random Tech Adj. Torque arm
-BMR Adj. Chromoly LCA's
-4.56 gears
-Removed the Brembos from the front and put the stock calipers back on.
-Bogart wheels, 28x10.50-15 ET Drags, & ET Fronts for up front.
There is alot more that was done, dry sump plumbing and such, also alot of fabing had to be done to make things fit and soforth, but Allan did it all! I highly recommend him.
Thanks Allan!
I also have a bunch of pictures taken during the build up, but..........SOMEBODY needs to download them from my camera and post them here! <img src="gr_images/icons/wink.gif" border="0">
Gordon
[ January 27, 2002: Message edited by: GTS SS ]</p>
Old Jan 26, 2002 | 06:08 AM
Frank95z's Avatar
Default Re: FMS Solid Roller Setup Madien Voyage@HRP
Gordon Glad to see you're back at it. Congratulations on the new times. I know you well enough to know that you're excited about the new changes to your car. Come on out to No-problem and visit. Frank95z
Old Jan 26, 2002 | 08:27 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Wow Gordon! I don't talk to you in forever, and the next I hear you're dry sump, solid roller, etc. Congrats on the new ET! I bet you crapped in your pants on the 1.52 60'. <img src="gr_grin.gif" border="0"> <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
__________________
Old Jan 26, 2002 | 08:53 AM
Ragtop 99's Avatar
almost 10s on the first time out, very cool.
Old Jan 26, 2002 | 10:30 AM
Colonel's Avatar
No doubt, an AWESOME shakedown run! <img src="gr_images/icons/cool.gif" border="0">
Old Jan 26, 2002 | 10:41 AM
PaiN's Avatar
Nice runs Gordon!
It was cool meeting you, and checking out the car. Very slick car man!
Larry
Old Jan 26, 2002 | 04:08 PM
GeorgeC's Avatar
Gordon, I see you have a '98. Do you still have the 97-98 perimiter bolt heads, or have you switched over to center bolt 99-up style heads? If you still have the '98 heads, what did you use to get clearance for the shaft rockers?
Damn good runs, BTW!!!
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Did the pistons have to flycut?
******' Awesome!
Old Jan 26, 2002 | 04:42 PM
GTS SS's Avatar
Thanks everybody,
Why HRP Tim? Why not? <img src="gr_images/icons/wink.gif" border="0">
Richie,
I have Wiseco pistons and they have valve reliefs cut into them already. BTW the lift of my cam is .680/.680 and I shift at 7000 rpm. I had the short block done up a little over year ago by More Performance, B&B, stock displacement, Wiseco pistons, Lunati Pro Mod Rods 6.125", Fedral Mogle Coated main bearings, Stock crankshaft & LS1 block cryogenicly treated.
Then I had Allan do the top end of the motor and other stuff as well.
George,
Yes I still have the 98 heads with the perimeter bolts, I got lucky and got a prototype set of spacers from Judson that they made to do some fittment testing. Thanks to Joe Kizzire I was able to get my hands on that set.
Gordon
Old Jan 26, 2002 | 06:26 PM
geauxlow's Avatar
Great run Gorden, 10's are so close you can taste them. Awesome 60' also. Hey I hear that Allan is the best around town, I guess that's so.
Old Jan 26, 2002 | 07:18 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
[quote]Originally posted by GTS SS:
<strong>
Why HRP Tim? Why not? <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
Why not NPR? Hell they have as good a track as HRP and they are only 45 minutes from BR, not 4.5 hours like HRP.
Tim
Old Jan 26, 2002 | 07:45 PM
GTS SS's Avatar
[quote]Originally posted by Tim98TA:
<strong>Why not NPR? </strong><hr></blockquote>
Wednesday, if it's not raining.
Old Jan 27, 2002 | 12:40 AM
Mike Hoffpauir's Avatar
And thats what I'm talking about. way to go gordon and allan <img src="gr_grin.gif" border="0">
[ January 26, 2002: Message edited by: Mike Hoffpauir ]</p>
Old Jan 27, 2002 | 12:48 AM
Son Of BeaSSt's Avatar
Congrats on the run! Wish I could have seen your run last night! 10's will be yours!
Stephen
ARE/FASTECH 432
www.thebeasst.com
Old Jan 27, 2002 | 12:52 AM
Tim98TA's Avatar
Don't they have 3 tracks in La.?????????
Why all the way to HRP?
Anyway, congrats on the new best. Now for the real test,,,,, come get some of the black TA!!!
Tim
Old Jan 27, 2002 | 01:14 AM
LEO's Avatar
LEO
Congrats!!! That must be one hell of a ride! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Jan 27, 2002 | 01:35 AM
Jason99T/A's Avatar
I can shift faster than you.
Congrats Gordo!! Kick *** times for your first trip out. Defintely more left in it after some tweaking. Congrats to everyone on a nice build up. <img src="gr_grin.gif" border="0">
Old Jan 27, 2002 | 07:49 AM
Frank95z's Avatar
For you guys who ask why Gordon went to HRP to run his car you don't understand how he thinks. It was as cold as Antarctica there,the track sticks like fly paper,and Gordon had twenty members of the Texas Bikini team standing on the side of the track spraying nitrous into the air as he went down. I'd call that first class conditions. Frank95z
Old Jan 27, 2002 | 10:27 AM
GTS SS's Avatar
[quote]Originally posted by Frank95z:
<strong>twenty members of the Texas Bikini team standing on the side of the track spraying nitrous into the air as he went down.</strong><hr></blockquote>
LOL
I wish!
Old Jan 27, 2002 | 11:11 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Gordon and Alan, kick *** times guys! You really have those solid roller setups working well guys. I wish I had gone to the track Friday, I heard the DA was better than -1000 ft! Bet HRP was a traffic jam like usual though, its been irritating to say the least.
Very good runs Gordon! Glad to see you back in action again.
Oh yeah, what is your full list of drivetrain/suspension mods? I really need that 1.52X short time to get me into the 10s. 4.56 gears must feel awesome in a 6-speed! What rpm were you crossing the traps in?
Tony
