Drag Racing Tech
buying drag radials this week ... suggestions please...
Old 04-12-2015, 08:05 PM
98CayenneT/A's Avatar
LS1Tech 10 Year
The nt05r is also a very good drag radial
Old 04-12-2015, 08:08 PM
HioSSilver's Avatar
LS1Tech 20 Year Member
I thought this was a good test.
DOT Drag Tire Test Video:
Old 04-15-2015, 10:57 AM
Dark SS's Avatar
Hoosiers are the **** but they are not for DDing or long distance at all. Get stuck in the rain once and you're screwed. I used to pull 1.5's out of my 17's, track or street. They dead hook and can be aired down lower than the Mikey's because they are glass belted. That is also why they are lighter.
Old 04-15-2015, 01:16 PM
T6Rocket's Avatar
Some things I noticed from that DOT drag tire test (other than it was from like 1998!):
I think the reason that the Hoosier did the best was not just from traction, but the fact it was a 27" tire, which helped the gearing. 28's are too much for a 12.30's M/T car.
Also, on most of the bias plies, the PSI appeared to be too low, causing the car to literally bottom out on the rim, then unload. I would have liked to see a couple more PSI to see if it helped.
A good video nonetheless!
Al
Old 04-15-2015, 06:24 PM
HioSSilver's Avatar
I thought the same as you about the test in some aspects. But the fact that they did it on the same day same track added a lot of validity to it. 1" in tire height would not be huge either way.....especially when you consider the bias will grow a bit.
Old 04-16-2015, 03:49 AM
SkWiDsTyLe321's Avatar
REALLY wanting hoosier 255/50R16 - can i safely drive these 30 miles to & from the strip (60 mile round trip) IF forecast is 99.9% no rain? (live in cali sacramento area so if no rain is in forecast it pretty much aint rainin lol) - after last night at the strip uhmmmmmm lets just say street tires are an absolute waste even with a stock a4 if you want to launch at anything above 500 !!!
Old 04-16-2015, 06:33 AM
Mystery Bird's Avatar
I drive mine to the track which is about 20 miles one way and no problems.
Old 04-16-2015, 12:52 PM
... & would you recommend them over the ET streets?
Old 04-17-2015, 06:30 AM
For drag racing an auto car yes, street driving no, because of the tread pattern or lack of. I only drive mine on the street to the track so I don't have to change them out at the track.
Old 04-17-2015, 12:23 PM
Drewstein's Avatar
I drive my MT ET Streets to the track. I never take them off the car. Now the car isn't my DD, but I still drive it to work sometimes, the track and back, car shows etc. It's so fun.
I run 295/55/15 and they dead hook 1.60 60' so far.
Old 04-17-2015, 08:49 PM
ok so i'm definitely leaning towards them, but my drive to the track would be 30 miles each way on highway (i could cruise control at 65) ... is that speed acceptable? again, i will ONLY be using these for driving from my home to the strip & back home.
Old 04-20-2015, 07:12 AM
  #32
I don't know about highway driving. My trip to the track I hit a max of 55 for about ten minutes the rest is up and down 35-50.
Old 04-21-2015, 03:07 PM
  #33
Dark SS's Avatar
I drove mine probably 40-50 miles one way to the track, all highway. I live in IL and the track I go to is in WI. 70-80 mph the whole way, aired them down, cut 1.5 60's, aired then back up and ran 75-80 home. Hoosiers FTW.
Old 04-21-2015, 06:42 PM
  #34
Guitar's Avatar
I drive 90 minutes one way to the track on Hoosier QTPs and skinnies multiple times (10+). It was fine. Dry weather driving is fine. Can't speak with radials on the front, I'd never put myself at risk like that. A drag radial on the other hand, who gives a ****. I've driven those on wet roads even and in slight rain, no problems.
Old 04-21-2015, 07:45 PM
  #35
you guys have convinced me ... hoosiers it is ... these suckers right here...
http://www.jegs.com/i/Hoosier/522/17325/10002/-1 ... & again i'm a4 stock other than intake, lid & muffler ... will my rear be leaking soon with these tires lol but seriously?
Old 04-21-2015, 08:21 PM
  #36
poltergeist 02's Avatar
LS1Tech 10 Year
Your rear end may hate life with a good tire, but I bet it will surprise you with how many passes you will get out of it before it does fail.
Old 05-11-2015, 01:03 AM
  #37
theskitztikwon's Avatar
Duude that car in your sig looks so close to a car that got solen from me although i can see some differences and am not saying its mine just that i had to do a double take.
Attached Thumbnails buying drag radials this week ... suggestions please...-2011-03-11_10-07-39_788.jpg
Old 05-11-2015, 01:17 AM
  #38
ASSuming On The Tree
audacious nick's Avatar
2 words: spotted showers. You could be driving home and enter an area where it has rained, or is raining, and you won't have enough time to slow before you hydroplane and lose control. It's really not worth it. Do people do it? Sure. But it's so much smarter to mount them to dedicated drag wheels and mount them at the track.
Old 05-11-2015, 02:38 AM
  #39
they WILL be mounted to dedicated drag wheels. im in california central valley ... if weather forecasts no rain believe me there is no rain coming lol. if rain is even suspected, sure ill bring the jack to the track & switch out there ... otherwise driving speed limit & granny-ish to & from.
Old 05-12-2015, 10:36 AM
  #40
Dark SS's Avatar
That sucks man. Yeah car looked nothing like that when I got it. It had a firehawk hood that I have since sold. I need to get my WS6 hood painted but it's going to need some fiberglass work first. That's the only reason it's still black.
Quick Reply: buying drag radials this week ... suggestions please...
