Drag Racing Tech
buying drag radials this week ... suggestions please...
Old 04-08-2015, 11:38 PM
SkWiDsTyLe321's Avatar
Default buying drag radials this week ... suggestions please...
first, i have 16x8's & 17x9's spare wheelsets - should i get them for my 16's or 17's? 2nd, should i get et street, street radial, or street radial 2's? the et streets i just dont understand if i need tubes or not, & what the proper size would be for either wheel on the et streets, as the radial & radial 2's have actual tire sizes listed. ... btw, my car is stock! just want to hook up as best as possible as even on backroads practicing launching at 16-1800 (auto) i spin for at least .3 to .5 seconds launching on my max performance summer tires.
Old 04-09-2015, 04:40 AM
nj02z's Avatar
I would be looking at the new ET Street SS. The regular ET Street Radial will be discontinued.
Old 04-09-2015, 07:58 AM
RENE'S RAGE's Avatar
Use the 16" rims, you can get more sidewall in a tire with them.
As far as a tire, get a ET Street Radial for an auto.
Old 04-09-2015, 09:05 AM
dsadsdaiouser's Avatar
Have you considered Hoosier? We run a 295/50/16 Hoosier drag radial and it works very well for us. Best 60' is 1.50 NA. I've used them on 3 cars now and have always had good luck. They don't require much of a burnout (IE lasts a long time) and have always hooked very well as long as the track prep is decent or better.
Scott
Old 04-09-2015, 09:25 AM
Scott
Is that a 26" or 28" tire.
Think he needs a 26" tire.
Good tire choice!
Old 04-09-2015, 10:51 AM
guppymech's Avatar
OP, You should list some details in your sarcastic signature, it will help get you accurate advice. A M6 car will do better on a bias ply tire. Get some M/T ET Street bias plys 26-10.5-16 and run them without tubes. This setup will be optimal for the strip. For a more street oriented setup get some DRs or if you have a A4.
Old 04-09-2015, 10:57 AM
Mystery Bird's Avatar
I've always run MT drag radials but switched to the Hoosier drag radials this season to try out because they are about 9lbs a piece lighter. We'll see how they do this weekend.
Old 04-09-2015, 11:16 AM
...thank you for the advice ... yet, clearly stated in post "...car is stock ...auto..." ___ but again, thanks much. - & yourself or anyone have an opinion on the toyo proxes tq's? i only ask because they are on sale in 255/50/16
Old 04-09-2015, 11:45 AM
Scott
liking the hoosiers over the et's so far as they are 7lbs lighter each in the size that i need. would anyone else say they are just as good ? if so, 14 lbs is 14 lbs less rotating weight & i'd be happy to go with the hoosiers
Old 04-09-2015, 01:35 PM
T6Rocket's Avatar
Go with the M/T 255/50-16 for stock power. I am sure the Hoosiers would hook better, but also would wear faster with a lot of street driving.
Just drive to the track with the M/T's already on.
Al
Old 04-09-2015, 06:01 PM
Al
well either i get will only be used at the track on a spare set of wheels ... so no street driving at all. would be nice to just drive with the M/T's on from the house already though ... so i guess final inquiry is - is the 14 lbs less rotating weight worth getting the hoosiers instead?
Old 04-09-2015, 07:11 PM
DadsZ28's Avatar
Interested in your results as i've been thinking about trying hoosiers against my mt drag radials also.
Old 04-10-2015, 11:15 PM
with my car at stock power level & being an auto, i'm seriously just considering the toyo proxes tq's 255/50/16, which are $160 each right now. i'm reading up, yes here on the forums, of guys dead hooking with them in the 400 hp range.
Old 04-10-2015, 11:55 PM
jhshnh's Avatar
I went with M/T 255s on my 16" stock snowflake rims. I love them! They ride great on the street and hook up great on the street as well.
Old 04-11-2015, 02:00 AM
yea its pretty much between those & the toyo proxes for me now, as i would like to be able to drive to & from the strip on them & not take extra wheels & a jack to the track.
Old 04-11-2015, 09:07 PM
nj02z's Avatar
Did you check out the new MT SS ?
Old 04-12-2015, 03:07 PM
don't see them available anywhere yet
Old 04-12-2015, 06:38 PM
spicebird98's Avatar
Nothing but happy with my toyo tq 255/50/16 on my old bolt on car.
Great wear and they hook. Right in between the Hoosiers and mickeys as far as wieght
Old 04-12-2015, 06:43 PM
nj02z's Avatar
McCormicks
Old 04-12-2015, 07:49 PM
Mike Morris's Avatar
This. Or the Hoosier like mentioned is much lighter but don't get caught in the rain with them
Quick Reply: buying drag radials this week ... suggestions please...
