Drag Racing Tech
Help me get traction....
Old Jan 28, 2002 | 03:57 PM
99taws6's Avatar
Default Re: Help me get traction....
oh, and if you say tires, what can I use without blowing the rear on my car.. ie DR's or full blown slicks.... TIA
Old Jan 28, 2002 | 04:21 PM
SS Mark's Avatar
Get either nitto or bfg drag radials, just make sure you warm em up first <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Jan 28, 2002 | 04:23 PM
99taws6's Avatar
Since I have an extra set of rims and I will be using the old TNT will I be wasting my money with DR's?
Old Jan 29, 2002 | 12:56 AM
99taws6's Avatar
Default Help me get traction....
Ok, I am ready to get some traction. I do not want to spend alot of money, but I would like to get better than a 2.3 60ft Time. I have never ran on a "Prepped" Track, but on a runway the 2.3 was my best 60ft time.
I am stationed in Germany and my best times to date are:
RT - .539
60ft - 2.3
1/8 ET - 8.81
1/8 mph - 89.5
This was on a poor track with me spinning through 2 gears and slightly into 3rd. What I want to know is what would be the best bang for my $$$. My car is being shipped to Atlanta in the morning and I want to have some traction when I hit the track. I already have Poly Torque Arm Bushing, Lower Control Arms w/relocation Brackets.....
Should I do tires? (Running Kuhmos now)
Should I do a Torque Arm? (Stock now with bushing)
Should I do something like springs or shocks?(Have Jamex 1.5" drop w/stock decarbons)
Thanks for your input and please provide links if applicable.....
Old Jan 29, 2002 | 06:44 AM
99taws6's Avatar
anyone?
Old Feb 1, 2002 | 03:33 AM
99taws6's Avatar
ttt
Old Feb 1, 2002 | 04:41 AM
JimmyKash's Avatar
hmm...have someone measure your pinion angle for you
usually when you lower a car you change the pinion angle to a positvie number which is BAD for traction.
i dont think you need an adjustable torque arm to fix it, you might. that is the first thing you should do
Then if the pinion angle is OK...the best bang for the buck would probably be
A)if you wanted some good traction on a spare set of rims, get some 26" ET Streets
B)if you wanted to use some nice tires on your stock rims, buy some NITTOS. They last a long time and hook like a **** as long as you heat them up and air them down at the track. They are also great in the rain (as long as they have tread on them). BFG's are stickier but dont last no where near as long as nittos. I have friends with over 8,000miles on a set of nittos. I haven't heard of many over 3,000 miles IF THAT on some daily driven BFGs
hope this was what you were looking for
