before i order, will the jegs DSL work for our f-bodies?
i see that Jegs has a pretty inexpensive Drive shaft loop for sale, around 30 bucks i think. i THINK 9-ball talked about it once. does anyone know if it fits nicely? i have only a 2.5" y-pipe so it should not bang. let me know before i buy it. thanks guys!
Re: before i order, will the jegs DSL work for our f-bodies?
Yes, it works. I have one on my car. You should cut the last two mounting bolt holes off of each side though, it makes it easier to install and you have more places to mount it this way.
Moving this to Dragracing section
Tony
Tony
so i should cut off the last couple of inches? that will make it not as wide but still be able to mount up? do i have to drill the floor at all? thanks again tony! my asian gangsta gangsta! <img src="gr_tounge.gif" border="0">
You want to make a cut on each side of the flat bars that mount the loop.
There are 4 hole on each end, you cut down the middle of each set. You want to cut off the outer most pair on each end
Yes, you need to drill 4 holes in the floor.
looks like this
looks like this
