Drag Racing Tech
Stock LS1 need advice.
Old May 22, 2015 | 08:13 AM
godawgsdv8's Avatar
Default Stock LS1 need advice.
I've read so many different post about head and cam packages. I'm looking for the best bang for the affordable buck. I looking into getting a set of 243 heads and getting a cam somewhere in the 575-600ish cam. What can ya'll tell me?
Old May 22, 2015 | 08:17 AM
HCI2000SS's Avatar
What are your goals and budget?
Old May 22, 2015 | 08:31 AM
elkydragger's Avatar
Auto or M6? Cam LSA will depend on trans. Also stall speed on converter if it is an auto. I have a few customers that i put comp 228r cams in with 243 heads and made awesome power. There are better cams out there. Just depends on your needs. For all out drag racing, pic your cam, measure piston to valve clearance, and have those 243's milled to .080" piston to valve clearance on the intake valve. You need .100" on the exhaust valve, but typically you will have more than that. The intake valve is much larger and at a 15 degree angle it will hit the piston sooner.
Old May 22, 2015 | 08:37 AM
01ssreda4's Avatar
Yep, need to know budget, goals, trans, etc. For stock ported castings I like TEA, AI, WCCH to name a few. For aftermarket I like AFR and TFS if budget allows. For cams there are a million choices. I agree on milling to get your ptv tight to maximize the combo.
Old May 26, 2015 | 09:19 AM
godawgsdv8's Avatar
It's an A4. I do race the car at the track. I want to get some where close to 450rwhp.
Budget is decent. Would like to save as much as possible. I was looking at the 228R cam and 243 cast heads. Don't know any thing technical about what to do. Only had car about 2 months.
Old May 26, 2015 | 11:44 AM
ragtopz28's Avatar
450rwhp is going to be hard to hit with a stalled auto. It's gonna take some BA heads and cam. Do you have headers yet?
Old May 26, 2015 | 08:04 PM
nj02z's Avatar
I would not fall into the trap of chasing dyno numbers. If you are serious about going fast at the track start with tires then converter and gears and then exhaust. You need tires first no matter what power you are making and the converter is the single best improvement you can make.My wifes car is solid in the 11's and the motor has never been touched. My car also was in the 11's before I touched the motor. The formula for these cars is pretty simple, 4000 converter,3:73 gears and 26"tire.
Old May 27, 2015 | 08:34 AM
Dark SS's Avatar
How many miles on your LS1? Are you planning any bottom end work?
Old May 27, 2015 | 10:18 AM
godawgsdv8's Avatar
It just hit 100,000.
Old May 27, 2015 | 10:22 AM
godawgsdv8's Avatar
I want the 243 heads and probably the 228R. What 228R variation is best? What needs to be to the heads to accommodate that cam?
Old May 27, 2015 | 10:33 AM
HCI2000SS's Avatar
I'd get the 228r on a 110 LSA
Old May 28, 2015 | 11:19 AM
godawgsdv8's Avatar
What do I need to have done to heads? Starting with stock 243 heads?
Old May 28, 2015 | 11:24 AM
Circle-D_Brian's Avatar
Converter will take a nice chunk out of your 60' times. A 3200 stall speed would compliment a 228 cam well. We can go higher for more performance if you want though. Let us know if we can help.
-Brian
Old May 28, 2015 | 11:26 AM
HCI2000SS's Avatar
Nothing should need to be done to the heads to accomade that cam
Old May 28, 2015 | 02:35 PM
Dark SS's Avatar
You're better off selling your LS1 and picking up a decent LQ4. Selling the 317's, buy an LS3 top end and have Tick spec you a cam. You'll hit 450rwhp with out even trying. Unless you have a low mileage LS1 I personally wouldn't mess around with a motor smaller than a 6.0 but that's just me.
Old May 28, 2015 | 05:17 PM
ragtopz28's Avatar
x2 ^^ that what I'm doing and looking for 500rwhp n/a + a 200-300 shot (and my SBE LS1 has only 17K!!).
Old May 30, 2015 | 08:04 PM
godawgsdv8's Avatar
Yeah you speak as if that's the easy way to do it. I want to use my ls motor. I want to improve it.
