8000foot DA, does anyone
Here's the breakdown:
1.94 60'
8.56 1/8
13.02@108.7 1/4
DA=8000 feet
temp: 82.5
alt: 30.01
dew: 37.0
track altitude: 5350 feet
I am just curious as to my corrected times.
Thank you.
Now, could I actually run an 11.49 if I drove down to a perfect race track?? I don't know, but I doubt it ... first, my poor rear end would explode, second, I'm not sure my clutch would stand up to the extra power. I'm just happy to know the potential is there with my baby cam ... I still have more modding to do!!!
as for the rest of the driveline not taking it, you are absolutely correct and that is why corrected ET has very little weight to most racers unless we are talking records.
so I can't really speak from experience. Have you really had opportunity to take your car up to a higher elevation??I know that when a friend of mine comes up from Roswell (3000 ft elevation) he notices a loss of 1.5 or so on the line and about 3 on the big end.
I've been playing balancing act with my car for a decent performer at both the strip and road course. So far it's going ok, but my RR suspension would further stack the deck against such a low ET.
So, in your opinion what can my car run at a good prep'ed track and good air?? SAE numbers for the car are: 397/394 and race weight is 3640 (w/driver)
I have plotted the correction factors from the NHRA. Its pretty much a line so all you have to do is extrapolate to the respective altitude.
Power has a lot to do with how you 60', but so do a lot of other factors. Your 60's aren't bad considering its also setup for the road course although I do think there is a 1.8 in there.
but then again if you guys want to bench race 60' times with correction factors, be my guest
BTW, I wasn't bench racing. I was curious to know what the correction would be that's all. It's hard to know how the car and mods are going when you have 8000 feet DA to overcome. Hell, the track is at 5350 feet. Even in perfect weather I would be down on time compared to most on this board just because of the altitude.
Gator, do you know how much of a difference 8000 ft. DA makes?!? That is huge! We’re talking nearly a second and a half in ET. Assuming the car is set up to hook (i.e. slicks or DOT slicks) with a dead hook I see no reason why he couldn’t sixty foot in the low 1.6’s if it’s a 6 speed car, 1.5’s if it’s an auto car with a stall converter.
But to say DA doesn’t effect sixty-foot times…THAT is laughable! I guarantee if you take a car like mine, that dead hooks 95 out of 100 launches, it'll go from high 1.5's in zero DA to somewhere around 1.8's or even 1.9's in 8000 DA!
Soliari, get your car to hook in near zero DA and you easily have an 11 second car. Probably an 11.60 car, maybe better. Again, it all depends on your launch.
I'm looking to get a 12.9x in this DA on my current setup and I'm looking to mid 12's in the Fall when the DA comes down.
FWIW on street tires we avg about 2.2-2.3 60's, when you sea level guys can pull off 2.0's.
Do you think its traction? because I can launch at 4500 on street tires and dead hook and barely pull 2.2's.
I've got the slips to back that up! Spinning well net you 2.4's
We are typically down 50-80 rwhp from you low alt. guys. so our times aren't exactly impressive.
Got my camaro, A4, lid only, ran it in Houston (HRP, 10ft elevation) with a -200ftDA:
1.970 (stock tires)
13.19@104.5
Two weeks later ran it in Roswell (3600ft elevation, 3800ft DA), same setup:
2.09
13.82@101.0
Zero spin on either race day. These runs were made in February and March of '02.
Later, after adding a ported maf, Vigilante converter, cutout and some Hoosier slicks, I ran in San Antonio (~500ft elevation), in right at 0ft DA:
1.74 (off idle)
12.45@108.0
That was made during the Clash of the Titans weekend in November of 2002. Two weeks before that I had ran in Roswell, with the same setup and 3600ft DA:
1.82
13.03@103.2
Again, zero spin. Funny thing is, the 60ft seems to be nearly on the same correction curve for altitude as the ET. Roswell's correction factor for elevation is ET x .9562 and MPH x 1.0465. **NOTE: This is the elevation correction, not DA correction to standard.**
Another one, with the current setup in Roswell I normally ran 12.85-12.95@104.5 with 60fts from 1.81-1.84. Went up to Albuquerque (elevation 5300ft) and best ETs there were 13.27-13.35 with mph at 102.5-103.0. 60ft times were from 1.85-1.87, again, this was on Hoosiers so tirespin is not a problem.
I've raced at 10ft, 500ft, 1300ft, 3100ft, 3200ft, 3600ft, 4050ft, 4100ft, and 5300ft elevations and I'll be damned if some yokel comes on with no experience in this area and tries to plead his case. I'll put up any or all slips, you name it and consider it done.
