Drag Racing Tech
Can't fit Lokar dipstick with carbon fiber trans shield TH400
Old 08-04-2015, 05:24 PM
Jason94z's Avatar
Default Can't fit Lokar dipstick with carbon fiber trans shield TH400
The fatter part of the dipstick before it goes round where the o-rings are, hits the shield so the angle is off and I can't push it in the hole.
I was going to take a grinder to the fat part of the dipstick - any other ideas before this gets sacrificed in an experiment?
Old 08-04-2015, 07:17 PM
Race your car!
JL ws-6's Avatar
notch the shield I just went thru this and it's not going to fit any other way.
Old 08-05-2015, 01:20 AM
8 Second Truck Club
Blown06's Avatar
Notched mine a bit to, but didn't tell anyone.
Old 08-05-2015, 09:00 AM
Race your car!
JL ws-6's Avatar
It's one of those things that you really have no choice but to do, Tech won't like it but they're not going to see it. I personally only plan to use the shield until I freshen the Trans and at that point will be going to the Sfi case.
Not cheap but has several good points one small one is not needing the shield anymore
Old 08-06-2015, 12:49 AM
8 Second Truck Club
Blown06's Avatar
I did paint the cut edge black. Doesn't even look modified.
Old 08-06-2015, 01:05 AM
Jason94z's Avatar
Thanks guys!
Grabbing the Dremel
Next time I'm splurging for an ultra bell - this shield has been a PITA start to end.
Old 08-07-2015, 12:59 AM
8 Second Truck Club
Blown06's Avatar
Wear a mask if you have one handy. Grinding on that **** is hazardous to your health I believe.
Old 08-07-2015, 10:14 AM
Race your car!
JL ws-6's Avatar
It absolutely is. Definitely wear a mask, and it does not cut easily at all.
Old 08-08-2015, 12:15 AM
Jason94z's Avatar
Well I currently have (unrelated) six stitches on my cheek. I was going to do this on the weekend, but, for safety sake I guess this will have to wait so no nasty things float into my fresh scar!
Or I can get someone to do it. Any volunteers?
Old 08-08-2015, 01:39 AM
8 Second Truck Club
Blown06's Avatar
I always cringe at the idea of having to cut/grind on carbon fiber, yet I'll grind red tungsten all day. WTF is wrong with me. lol
Old 08-09-2015, 06:24 PM
Jason94z's Avatar
Wore a mask
Sure made a mess!
Got this carbide attachemtne for cutting fiberglass, it worked pretty good.
Ugly but it's in
Old 08-10-2015, 05:55 AM
Race your car!
JL ws-6's Avatar
Now paint that edge, and. Lone would even notice it's been trimmed.
Old 08-12-2015, 08:37 PM
Zmg00camaross's Avatar
Awe I am telling!!
Old 08-13-2015, 10:27 AM
Race your car!
JL ws-6's Avatar
It's literally impossible to put one of those on and not have to cut it at all. I have no idea if they will re-cert one that's been cut at all.... But I've never had a tech guy question he sfi # that I have written down on the laminated paper I hand them with every sfi number off the car ( balancer, flywheel, shield, seatbelts, window net, etc. Every tech guy looks at that, looks at the belts and helmet, usually asks about the kill switch working, makes sure the battery box is secure, and that's about it. They can usually tell if you have your **** together or not.
Nhra national event, or something big like that I'm sure it will be a more intense inspection... But again I highly doubt they're crawling under the car to look to see if the shield has been modded at all, or if it's in date or not. If they look they're looking for evidence it's there ( strap under the Trans pan)
Old 08-13-2015, 10:55 AM
If I went to a track and wouldn't let me race because of that I would be pissed. But rule is anything SFI and you modify it equals fail.
Old 08-13-2015, 08:06 PM
Race your car!
JL ws-6's Avatar
Then how do people get away with sfi certified fuel cells that have the foam removed?
If I change the bolts in my SFI approved double beadlock wheels to titanium bolts are they now illegal?
I understand what you've getting at but believe me when I say there's no way to get that csr shield on with any lokar dipstick product, and sometimes you just can't get away with a rigid tube dipstick.
I don't condone/promote doing it, but like I said. Show up with a laminated list of every SFI item you have with the # and the "date" that it's good until, and see if anyone questions it. They will check your belts, helmet, see that those are up to date and the #'s match your paper, and if they do, likelihood is that you're going to pass.
Old 08-13-2015, 10:06 PM
O yeah no doubt. If I was a inspector I would pass it just fine.
Old 08-18-2015, 12:03 AM
Jason94z's Avatar
By the time this paperweight makes it to the track, I'll need all new stuff to pass all the dates anyhow!
Old 08-18-2015, 02:45 AM
98Camarod's Avatar
I didn't have a problem with my lokar and csr shield. There is a molded cutout with it. I did put the dipstick in first and then put the shield on while they were out of the car though.
Old 08-18-2015, 06:27 AM
Race your car!
JL ws-6's Avatar
I tried all that chief, it won't work without forcing the shield over which makes it fit like ****, and then it rubs on the floor in the car.
My dates are all out. But that BS is just that, BS. It's a scam to get money to re-inspect. Just like the seatbelt 2 year rule. Just a scam to make you keep buying belts.
Quick Reply: Can't fit Lokar dipstick with carbon fiber trans shield TH400
