lt1 ls1 lid swap pics and question
Here is the Sunoco VFN pin-on sitting over the lid no problems:
No stock hood. I did not want to hack things up, so I ordered the standard VFN Sunoco pin-on exactly for running this lid setup, and it just clears. FYI the Sunoco bolt on will not clear, unless you get the Sunoco Wide version, *and* tell them to modify it so you can run the lid. With the pin-on, no modifications are required at all to either the hood or the upper cross member on the car.
