4.8L/5.3L unicorn blocks
I've tried searching but really can't find much on these blocks. There are gm 4.8L and 5.3L blocks that are stamped "4.8L" or "5.3L" on front passengers side of the block. Most 4.8/5.3L blocks can be bore to ls1 size bores but that's about it. These blocks were supposedly the same starting/casting blocks as the 6.0L blocks; therefore, they can be bore out past 4" just like the 6.0L blocks. Is there a way to know which year range and vehicle type these were put in? Does anyone know anything about these blocks???
Yep, here also. I'm specifically interested in ones that have the 4.8L or 5.3L that are stamped on the front passengers side of the block. . . like the post says. Trying to find out more info on those specific castings.
99-present Silverado, Tahoe, suburban, sierra, and most mustangs around here.
make sure to sonic check your 5.3 if you plan to go to a 4" bore. I've HEARD that the gen 4 5.3 has thinner walls, so I would stick to a gen 3 iron block to be safe. all of the blocks I've seen have the CI stamp on them.
'Bird Director
That's an "old wives' tale". The 4.8 and 5.3 iron blocks had both displacements stamped on the front of the block. Like mentioned above, the only way to tell the which one you have or are buying is by pulling a head and looking at the pistons. 4.8 got the flat topped pistons.
