Drag Racing Tech
Custom dash setups... I gotz q's
Old Jun 15, 2004 | 04:30 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Custom dash setups... I gotz q's
I see some folks have custom setups, any tips or suggestion on those setups?
Old Jun 15, 2004 | 05:00 PM
SilverGhost's Avatar
Motorboater
um, details?
my radio bezel has the vents removed and guages in there with a custom panel instead, that's about it for me.
Old Jun 15, 2004 | 05:17 PM
Tom the roofer's Avatar
You mean like this?
Old Jun 15, 2004 | 05:29 PM
LS1Tech Co-Founder
Yah like that Tom... dang.
Any tips on doing that?
Old Jun 15, 2004 | 05:31 PM
770Guy's Avatar
Yeah thats pretty nice, I would love to do something like that with mine.
Old Jun 15, 2004 | 05:53 PM
Shean Freese did this for me. The speedo don't work because my tranny dosn't have the hook up. The gauges are all electronic. The tach and shift light are Auto Meter.
It is a piece of aluminum sheet metal cut to fit the opening. Drill holes to accomodate the gauges and use the hardware that comes with the gauges.
The switches are Moroso.
The gauge cluster consists of:
200 mph speedo (doesn't work yet and probably never will)
tach
shift light
temp
fuel pressure
oil pressure
volts
fuel level (you can't see the fuel level because the steering wheel hides it).
The Moroso switch panel consists of:
Momentary start switch
fuel pump
water pump
fans
2-step
spare not hooked up.
The big red button on the steering wheel is the line lock.
Old Jun 15, 2004 | 05:55 PM
PS the steering wheel is hiding the shift light also. You can barely see it between the tack and speedometer
Old Jun 15, 2004 | 06:48 PM
xxx's Avatar
xxx
Default Mine
http://teamprickracing.com/95z/day3/MVC-210F.JPG
http://teamprickracing.com/95z/day3/MVC-206F.JPG
I'll look to see if I have some pics of it actually installed in the car.
Shannon
Old Jun 15, 2004 | 07:05 PM
383ss's Avatar
nice XXX, had never thought of doing anything like that. looks like a good winter project
Old Jun 15, 2004 | 07:10 PM
LS1Tech Co-Founder
Yah I think I am going to do a setup like that as soon as I can find a stock cluster to use as a reference. I don't want to cut up my dash while the car is still waiting to make passes.
Old Jun 15, 2004 | 07:28 PM
Shannon
Looks awesome.
Old Jun 15, 2004 | 08:09 PM
xxx's Avatar
xxx
Default sdffsd
Thanks
I actually built it using the plastic from my old console, some gauges, a dremel, and some handy dandy JB weld....
....oh and a few beers
Old Jun 15, 2004 | 09:42 PM
Motorboater
beer being the secret ingredient?
Old Jun 16, 2004 | 05:47 AM
xxx's Avatar
xxx
Default ;kigffj
Oh yes......
Old Jun 16, 2004 | 08:07 AM
mongse's Avatar
I ruin the end of films...
The cars may be pump gas, but the entire TPR crew runs on alcohol.
Old Jun 16, 2004 | 08:20 AM
CHRISPY's Avatar
very nice work fellas!
