turbo 402 1/8th mile
6.0 402CI garret 4788, 234-236 cam th400, 3.00 rear gear, magnafuel 4303 on e-85 holley 160lb low imp inj, holley dominator, c02 controlling the boost. Datalog says 22 psi on this pass and the fuel pressure dropped off to 50 psi around the 2nd gear shift. base pressure is set at 50psi 1:1 regulator -10 feed and return. Going to smoke it and boost leak test the car, it does not seem to be making 22psi with this trap and MPH. Motor made 1143 before with a 6speed.
