Best method for trimming the cowl?
Do not touch windshield or you're buying a new one.
You can cut it and keep the wipers, won't be the prettiest but the cowl plastic will cover a lot of it up.
Super victor is a lot better I take I agree with the statement to go with one.
Wilson throttle body about the best one power wise I have seen fwiw.
I would just use a cutoff wheel, and if you have a friend have them hold a running shop vac near it to help contain the mess.
Also I have already purchased the jr. so no going back. Plus I need the extra clearance for a nitrous plate.
If you're stuck running a 4150 then you may want to run it on the passengers side and make a 180 degree loop around to the firewall, all depends what and how much trimming you did.
Did you put a set of poly or solid motor mounts in the car? If you did then the amount of clearance needed will be less and that will help your cause, a custom set of solid ones would allow you to drop the motor a little and get a lot more clearance. Just a thought.
Make sure youre prepared to do this there isnt any going back I had to cut a lot more than I anticipated. I wouldve bought another fast and direct port if i knew the change was so involved. You cant beat the look though
The problem is a fast intake and nitrous is 1 back fire and you're spending another $800+. I also believe the vic jr offers a much more consistent flow to each cylinder which will keep a stock bottom end alive longer.
I'm hopefully finishing up trimming the cowl today and will post up some pics.
I haven't decided between a plate of puck but it has a 1" spacer on it. Either I'll keep it with the puck or the plate will replace it.
