26" vs 28" tire
MT ET Street R's and my street tires up front. I don't want to be changing tires at the track and leave my stuff out in the open. I know I can ask someone to watch over them while I run but who needs the worries.
I guess eventually a car hauler is the way to go. I can try and drive the slicks and skinnies all the way there but that's not ideal either.
Cops don't like them either if you have some of that in the area as well.
And unless you added HP from the last time out, I would expect to run 127 MPH again, possibly lower from the increased rolling resistance of slicks. And you have to factor the lower RPM you will be turning with the 28's at the stripe, which equals lower MPH.
I agree with the people that said stay with 26's. You will need a gearing change to get back to where you were.
Good luck with it.
Al
Installed a 2 step and came to test it out. Dropped the clutch and nothing, just sat there. Didn't hear a pop or anything mechanical. No gears, and a 200 dollar tow to show for.
Good time to swap gears I guess.
Drove 60 miles just fine. No leak, no broken bits. I can put it in gear with the car running and the drive shaft doesn't move. I can do this without pushing the clutch in. Car rolls fine.
Weird, no noise at all from possible broken parts.
There is a chinese alternative, strength is a questions as it is not as good. Also, need to consider that at my power level, the input shaft will be next on the failure list.
I am told to think about a T56 Magnum, supposed to handle 1,000hp no problem.
That thing is $3,900.00
