removing bumper supports TONIGHT help! will it sag?
removing my bumper supports tonight, do I need to remove the entire bumper?
will the bumpers sag then?
are you guys making different mounts to hold them?
are trans am fog lights attached to the bumper support?
come on HELP! guys. Everyone says they removed theirs but there are no details on it????
LS1Tech Co-Founder
Re: removing bumper supports TONIGHT help! will it sag?
I think it will sag.
I have not pulled my front out yet since I need to make a bracket to hold up the center of the nose.
Mine didn't sag, but The techs at MTI whipped up some sweet little brackets to hold the front, and rear fascia's secure for making 1/4 blast.
Thanks again guys!
Thanks again guys!
how do these homemade brackets work. you don't have to drill througn the bumper to bolt them in do you? out to start project weight reduction now!
I havent had mine on my Formula for a few months and no problems yet <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
like i said it will not sag. ive had my front and rear off for a year now w/ no homemade brackets or anything and i drive it everyday the weather is good.
I've had mine off of my T/A for a few months. No problems whatsoever. You will lose your fog lights though they do mount to it. Although with no fog lights it does make for an interesting ram-air setup. Havent gotten around to trying it yet.
well I saw a webpage where someone rigged up two little tunnels from the foglight area right up to the airbox...it was on a camaro though, I think it can be done on the t/a, is there really any noticeable difference with it off?
I have had the front off of my Z-28 for about 2 years now,no brackets or anything and it does not sag at all. It does however collect rainwater, leaves etc.
anyone have any links to any webpages on how to do it? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
When removing the bumper cover, the only difference between a camaro & firebird is the firebird has a small screw on each side under the headlights.
For a Formula.. no brackets are needed for the fog/driving lights... the facia supports them.
