Going to the track sat! Diff psi for dr's ?????
I was running Mt et streets at 17 psi and did a John force burnout every pass in the water box and dead hooked every pass.
Don't be afraid to heat the **** out of them if need be. Long third gear burnout and get the smoke rolling if that is what it takes to hook
After your first pass they will probably jump up to around 19psi due to the heat then after you drop them back down to 17 psi after the first pass you should be good.
Yes the colder air helped. Previous best in 1500 da was 12.4@109.
On the 40 degree day the da was around 0 and I ran consistent 12.2@111 mph
Start at 20 psi cold. Make a pass and check them. You should be at 21-22 psi warm. If they hook, go with it. If they spin, drop in 1 psi increments until they hook. 14 psi is the lowest I'd try. If you still can't hook, time to look at your suspension.
All you need is to see some decent smoke off the tires. If A4 w/linelock, roll just out of the water and start the burnout in 2nd. Come up on rpm on the brake and hammer down. When it hits close to redline, feather throttle for a second, disengage line lock and hammer down for 5ft or so. You should notice the smoke and have plenty of heat in the tire. (A consistent burnout results in consistent ET's.)
All a John Force burnout does is waste money on tires.
My best 60' came with 17 psi and a good size burnout. Never ran Nitto, but I think you probably need some heat in them. But I do know every car with drag radials has its sweet spot, and when you adjust your tire pressure between runs to get the best 60' make sure you only adjust around 2 psi. Don't jump around the place with tire psi. I hooked at 17 psi, and spun at 20 psi to give you an example.
