Who has the fastest cam only car record ?
Originally Posted by Roger White
If your car does not 60 ft. better on a transbrake, then I say it is not set up correctly.
I knew this would ruffle some feathers.
Can you tell me how many other people here cut 1.32-1.35 60's @ 3470 lbs race weight and Factory Stock setup on the footbrake AND the transbrake?
Whats your 60's with your car? Damn if my cars 1.35 60' footbrake isn't setup right, yours must really be f**ked up.
No ruffled feathers here.. after all I am just about the fastest 346ci LS1 on here, its all good.
Lee
Holy cow.
Ok, here's MY take on this stuff.
My heads have never been off the car.
I have a G5X-2, ALL the bolt ons.
I have a TH400 with a 2.45 1st gear( not a 3.06 4L60E)
I would have run DEEP in the 10.70's @ NvsS if I was not bracket racing.
I will get a bigger cam and go faster.
Yeah Lee you don't know what you are talking about cause your **** don't run worth a crap.
Our new converter is on the way so I'll be 60'ing with ya soon.
Paul
Paul
Paul
Hrmm how about I trade ya my converter for that sheetmetal intake ya got ?
hehe
Come on Paul you don't want to really change converters do you?
Yeah my 60s sucked. 1.46 at weight.
Paul
Originally Posted by 01-Z
...I would have run DEEP in the 10.70's @ NvsS if I was not bracket racing...
Steve...
Yes I was sandbagging
I was running slower earlier.
the 1st 2 runs are throwaways, then the car picks up, always.(maybe have to do with disconnecting the battery)
My first 2 runs were 10.92 and 10.87 on 1.51 and 1.52 60's
the mph was over 125 on the second pass.
then the so -called "brackets" started.Car got up to potential (1.46) 60's
I was catching most people by 660' and peddling the car.
My 660' were WAY better than my 10.77 pass(et and mph)
If I had guys cutting good lights and running on thier dial in, I would have broke out.
One of those lucky days I guess.
I ran 3 'practice rounds', but nobody REALLY knew what was going on, so I just let off
after I caught them.(Just to be safe)
I came to win brackets, not ET race.
I would have liked to run them out,But I was focused on doing what it took to win.
About as many that have a built, solid roller 347 and 5k plus stall.
Is you car a cam-only car? I really don't see why you’re dragging your car into this. I am talking about cam only cars,(not F/S) which have for the most part, have been the street type cars. What is your best cam-only 60ft and I will tell you if I am impressed or not.
I am impressed with your car. Great times...Think it would run that with a 4l60e?
Btw: get that transbrake looked at cause you’re leaving time on the table. I am sure you already knew that.
[b]Is you car a cam-only car? I really don't see why you’re dragging your car into this. I am talking about cam only cars,(not F/S) which have for the most part, have been the street type cars. What is your best cam-only 60ft and I will tell you if I am impressed or not.
definatly cam only, 100% stock original transmisson. it went 11.11@122 w/1.48 60ft on stock shocks in 2500da about 20min after jason went 11.08 in his. then in better weather he went high 10.7's with 3250lbs.
im in the process of doing some weight removal, so come our first decent cool front i dont think 10.8's will be a problem.
#35
#38
Originally Posted by SMOKIN01TA
overall 01-z has it temporarilly, but with a manual jason deff has it.
BTW, when you gonna spray that bitch Sean? Isn't the 'verter that's in it now set up as more of a nitrous converter than an N/A converter?
#39
Originally Posted by QwikFix
Not arguing that, i agree 100%. I'd like to see what Sean's car could do with a bigger cam.
