Drag Racing Tech
Paging 6.90 or faster NA folks (1/8th)
Old 05-13-2002, 05:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Paging 6.90 or faster NA folks (1/8th)
What converter / gear/ tire combo do you have?
I've got a Yank TP3600E and it's too tight I think.
John
7.10-7.15 1/8th MAN
Old 05-13-2002, 05:04 PM
Colonel's Avatar
Default Re: Paging 6.90 or faster NA folks (1/8th)
6.25 here.
Yank 250mm TP4600E
4.10
29x10x15 Hoosier
Old 05-13-2002, 05:11 PM
LS1Tech Co-Founder
I sure need more stall.
Old 05-13-2002, 05:17 PM
GeorgeC's Avatar
John, you know my combo...
4.33 gears
28" slicks
~4500 stall
Was good for mid 6.8's with the old motor.
Old 05-13-2002, 05:18 PM
Colonel's Avatar
How'd you end up with that stall? Was thinking N2O or something?
Old 05-13-2002, 05:31 PM
LS1Tech Co-Founder
We thought it was stalling too high and sent it back to Yank to get it tightened up. Turns out it was another issue.
Perhaps a TP4400E will get my the 6.8's I so do crave. (Nicolas Cage's character in Raising Arizona)
Old 05-13-2002, 07:45 PM
Jantzer98SS's Avatar
I don't qualify at 6.91, but I run the TP4400, 4.10, Hoosier 26" DOT/Full slick, both worked well.
I would like to try the TP4600, but I'll add a little more power first. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I think you definately need more stall.
Old 05-13-2002, 11:06 PM
JimmyKash's Avatar
spray the car and watch what happens with that converter <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old 05-13-2002, 11:41 PM
LS1Tech Co-Founder
28x10 Hoosiers will be on the car next time, and hopefully it will run a 10.xx, I have also done some other minor things.
I'm thinking TP4400E and is just a restall away. But Jimmy da K I am in fact thinking of wacking the car with a 100 shot before I pull the converter out. If it blows up it would give me an excuse to flow the heads.
Old 05-14-2002, 07:46 AM
BIGBOS's Avatar
Why don't you just get one of those Yank Extreme converters John?
Then you can still spray the car, but have a solid 4000flash on motor.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 05-14-2002, 08:28 AM
CHRISPY's Avatar
PSJ,
I think the TP4400 with 3.73's and 26x10 inch slick would work great in your combo. I wouldnt go any higher than that.
Cheers,
Chris
Old 05-14-2002, 11:12 AM
Colonel's Avatar
BTW, his character was "H-I."
"...and I'll be taken these here Huggies too." <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Old 05-14-2002, 11:17 AM
Terry Burger's Avatar
I'm trying to join the 6.9 1/8th club. I run a TP4400, 4.10s, 26" tires. 3370# raceweight at the time.
Old 05-14-2002, 11:25 AM
LS1Tech Co-Founder
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>PSJ,I think the TP4400 with 3.73's and 26x10 inch slick would work great in your combo. I wouldnt go any higher than that. Cheers, Christ</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Pippers, Well 28x10 Hoosier slick + 4.10 is pretty much the same with more torqualocity out of the hole. I do have a set of 3.70's lying around but would only drop down if I was gonna wack the car with a 250+ shot of NOOOS.
Bos, I already have an Extreme 'verter (TP3600E) that is perfect for DA GUN. That's what the E stands for my son.
That settles it, I will pull the 'verter out after I hit the track on more time.
We think the UT would be too much for my motor right?
Old 05-14-2002, 11:28 AM
CHRISPY's Avatar
ahh I thought you had 3.73s for some reason sorry bout that <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yes a 4.10 with a 28 inch Hoosier would be the **** with a TP4400 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris
Old 05-14-2002, 01:07 PM
DriveATransAm's Avatar
im thinking byron might be a nice time to try out that tight converter on the gun <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
